How to use the AI module
where is the api for the NPU and description
The easiest way is to use the Qualcomm AI hub and generate models for the QCM6490, which will automatically use the NPU and DSP. See the developer docs for how to get started.
Or do you really need direct access to the NPU?
i need to run a onnx file
or a way to do it
for object detection
The Qualcomm AI hub should support the ONNX runtime.
:slight_smile:es i will Waite for ubuntu 24.04 to be released nice hardware.
but i am danish so my key board is a lot different from us one and local Da don’t work on 20.04.:slight_smile:
