How to use a library with Boron 404X and CLI?
I must be doing something wrong, but I can't seem to get any of the OneWire or DS18B20 libraries to compile for a Boron.
For example, OneWire | Reference | Particle shows green checks for 'boron', so that means it should compile, right?
particle project create, name it test, Y
cd to project directory
particle compile boron: worked!
particle library add OneWire: " Library OneWire 2.0.4 has been added to the project."
Compiling code for boron
Including:
    project.properties
    src/test.cpp
Compile failed: Checking library OneWire...
Installing library OneWire 2.0.4 to lib/OneWire ...
Library OneWire 2.0.4 installed.
make -C ../modules/boron/user-part all
make[1]: Entering directory `/firmware/modules/boron/user-part'
mkdir -p target/
make -f ../../../modules/shared/nRF52840/build_linker_script.mk PREBUILD=1
make[2]: Entering directory `/firmware/modules/boron/user-part'
Creating target/platform_user_ram.ld ...
make[2]: Leaving directory `/firmware/modules/boron/user-part'
make -C ../../../user
make[2]: Entering directory `/firmware/user'
Building cpp file: src/test.cpp
Invoking: ARM GCC CPP Compiler
mkdir -p ../build/target/user/platform-13-msrc/
arm-none-eabi-gcc -DMCU_DEVICE -DnRF52840 -DNRF52840_XXAA -DPLATFORM_THREADING=1 -DPLATFORM_ID=13 -DPLATFORM_NAME=boron -DPLATFORM_GEN=3 -DUSBD_VID_PARTICLE=0x2B04 -DUSBD_P
ID_DFU=0xD00D -DUSBD_PID_CDC=0xC00D -DSPARK_PLATFORM -fno-builtin-puts -fno-builtin-printf -Wl,--wrap=puts -Wl,--wrap=printf -Wl,--wrap=_printf_i -Wl,--wrap=_svfprintf_r -W
l,--wrap=_scanf_i -Wl,--wrap=__ssvfscanf_r -g3 -gdwarf-2 -Os -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DARM_CPU_CORTEX_M4 --specs=nano.specs -
DINCLUDE_PLATFORM=1 -DSOFTDEVICE_PRESENT=1 -DS140 -DPRODUCT_ID=13 -DPRODUCT_FIRMWARE_VERSION=65535 -D_WIZCHIP_=W5500 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DLFS_CONFIG=
lfs_config.h -DSYSTEM_VERSION_STRING=6.2.1 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../services/inc -I../third_party/nanopb/nanopb -I../communication/inc -
I../hal/inc -I../hal/src/boron -I../hal/network/lwip/cellular -I../hal/src/nRF52840 -I../hal/src/armv7 -I../hal/src/portable/FreeRTOS -I../hal/src/nRF52840 -I../hal/src/nRF
52840/lwip -I../hal/src/nRF52840/freertos -I../hal/src/nRF52840/mbedtls -I../hal/src/nRF52840/littlefs -I../hal -I../hal/src/nRF52840/posix -I../hal/network -I../hal/networ
k/api -I../hal/network/lwip -I../hal/network/lwip/posix -I../hal/network/lwip/wiznet -I../hal/network/ncp -I../hal/network/ncp/at_parser -I../hal/network/util -I../third_pa
rty/lwip/lwip/src/include -I../third_party/freertos/freertos/FreeRTOS/Source/include -I../third_party/nrf5_sdk/nrf5_sdk/external/freertos/portable/GCC/nrf52 -I../third_part
y/nrf5_sdk/nrf5_sdk/external/freertos/portable/CMSIS/nrf52 -I../third_party/wiznet_driver/wiznet_driver/Ethernet -I../gsm0710muxer/gsm0710muxer/include -I../hal/shared -I..
/platform/shared/inc -I../third_party/nrf5_sdk -I../third_party/nrf5_sdk/nrf5_sdk/components/toolchain/cmsis/include -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx -I../th
ird_party/nrf5_sdk/nrf5_sdk/modules/nrfx/drivers -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/drivers/include -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/hal -I../th
ird_party/nrf5_sdk/nrf5_sdk/modules/nrfx/mdk -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/hal -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/drivers/src/prs -I../third_
party/nrf5_sdk/nrf5_sdk/components/libraries/util -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140/headers -I../third_party/nrf5_sdk/nrf5_sdk/components/softde
vice/s140/headers/nrf52 -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/common -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/mbr/nrf52840/headers -I../t
hird_party/nrf5_sdk/nrf5_sdk/components/libraries/fstorage -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/experimental_section_vars -I../third_party/nrf5_sdk/nrf5_
sdk/components/libraries/atomic -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/crc32 -I../third_party/nrf5_sdk/nrf5_sdk/integration/nrfx/legacy -I../third_party/nr
f5_sdk/nrf5_sdk/components/libraries/delay -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/log -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/log -I../thir
d_party/nrf5_sdk/nrf5_sdk/components/libraries/log/src -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/experimental_section_vars -I../third_party/nrf5_sdk/nrf5_sdk/
components/libraries/atomic -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/delay -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/queue -I../third_party/nrf
5_sdk/nrf5_sdk/components/softdevice/common -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140 -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140/head
ers -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140/headers/nrf52 -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/fifo -I../third_party/nrf5_sdk/nrf5_
sdk/components/libraries/atomic_fifo -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/strerror -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/fstorage -I../
third_party/nrf5_sdk/nrf5_sdk/components/libraries/atomic_flags -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/usbd -I../third_party/nrf5_sdk/nrf5_sdk/components/l
ibraries/usbd/class/cdc -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/usbd/class/cdc/acm -I../third_party/nrf5_sdk/nrf5_sdk/components/ble/common -I../third_party
/nrf5_sdk/nrf5_sdk/components/ble/nrf_ble_gatt -I../third_party/nrf5_sdk/nrf5_sdk/components/ble/ble_advertising -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/t2t_lib -
I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/platform -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/ndef/generic/message -I../third_party/nrf5_sdk/nrf5_sdk/componen
ts/nfc/ndef/generic/record -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/ndef/lauchapp -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/ndef/text -I../third_party/nrf5
_sdk/nrf5_sdk/components/nfc/ndef/uri -I../third_party/nrf5_sdk/nrf5_sdk/external/nrf_cc310/include -I../third_party/nrf5_sdk/nrf5_sdk/external/utf_converter -I../third_par
ty/littlefs/littlefs -I../third_party/miniz/miniz -I../platform/MCU/nRF52840/inc -I../dynalib/inc -I../hal/shared -Isrc -I./libraries -Ilib/OneWire/src -I. -MD -MP -MF ../b
uild/target/user/platform-13-msrc/test.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -fmessage-length=0 -Wno-error=deprecated-declarations -Wno-error=unused-par
ameter -Wdeprecated-declarations -Wimplicit-fallthrough=2 -Wno-expansion-to-defined -Wno-cast-function-type -Wno-unused-parameter -Wno-error=type-limits -fno-strict-aliasin
g -DSPARK=1 -DPARTICLE=1 -Werror=return-type -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSPARK_PLATFORM_NET=UBLOXSARA -fno-builtin-malloc -fno-builtin-free -fno-builti
n-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DUSER_FIRMWARE_IMAGE_SIZE=0x40000 -DUSER_FIRMWARE_IMAGE_LOCATION=0xB4000 -DMODULAR_FIRMWARE=1 -DMODULE_VERSIO
N=6 -DMODULE_FUNCTION=5 -DMODULE_INDEX=2 -DMODULE_DEPENDENCY=4,1,6201 -DMODULE_DEPENDENCY2=0,0,0 -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fno-rtti -f
check-new -flto -ffat-lto-objects -DPARTICLE_COMPILE_LTO_FAT -fno-use-cxa-atexit -std=gnu++17 -c -o ../build/target/user/platform-13-msrc/test.o src/test.cpp
src/test.cpp:16:13: warning: System thread is enabled by default starting with Device OS 6.2.0. SYSTEM_THREAD(DISABLED) may still be explicitly called, however non-threaded
 behavior is soon to be completely deprecated in later releases.
   16 | SYSTEM_THREAD(ENABLED);
Building cpp file: lib/OneWire/src/DS18.cpp
mkdir -p ../build/target/user/platform-13-mOneWire/src/
uild/target/user/platform-13-mOneWire/src/DS18.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -fmessage-length=0 -Wno-error=deprecated-declarations -Wno-error=un
used-parameter -Wdeprecated-declarations -Wimplicit-fallthrough=2 -Wno-expansion-to-defined -Wno-cast-function-type -Wno-unused-parameter -Wno-error=type-limits -fno-strict
-aliasing -DSPARK=1 -DPARTICLE=1 -Werror=return-type -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSPARK_PLATFORM_NET=UBLOXSARA -fno-builtin-malloc -fno-builtin-free -fn
o-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DUSER_FIRMWARE_IMAGE_SIZE=0x40000 -DUSER_FIRMWARE_IMAGE_LOCATION=0xB4000 -DMODULAR_FIRMWARE=1 -DMODUL
E_VERSION=6 -DMODULE_FUNCTION=5 -DMODULE_INDEX=2 -DMODULE_DEPENDENCY=4,1,6201 -DMODULE_DEPENDENCY2=0,0,0 -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-exceptions -fno
-rtti -fcheck-new -flto -ffat-lto-objects -DPARTICLE_COMPILE_LTO_FAT -fno-use-cxa-atexit -std=gnu++17 -c -o ../build/target/user/platform-13-mOneWire/src/DS18.o lib/OneWire
/src/DS18.cpp
In file included from lib/OneWire/src/DS18.h:4,
                 from lib/OneWire/src/DS18.cpp:1:
lib/OneWire/src/OneWire.h: In member function 'void OneWire::pinModeFastOutput()':
lib/OneWire/src/OneWire.h:136:7: error: 'HAL_Pin_Mode' was not declared in this scope
  136 |       HAL_Pin_Mode(_pin, OUTPUT);
lib/OneWire/src/OneWire.h: In member function 'void OneWire::pinModeFastInput()':
lib/OneWire/src/OneWire.h:142:7: error: 'HAL_Pin_Mode' was not declared in this scope
  142 |       HAL_Pin_Mode(_pin, INPUT);
make[2]: *** [../build/target/user/platform-13-mOneWire/src/DS18.o] Error 1
make[2]: Leaving directory `/firmware/user'
make[1]: *** [user] Error 2
make[1]: Leaving directory `/firmware/modules/boron/user-part'
make: *** [modules/boron/user-part] Error 2
Not what I expected!
Delete that project and start another, this time with DS18B20 | Reference | Particle
which also shows green checks for Boron:
Including:
    project.properties
    src/test.cpp
Compile failed: Checking library DS18B20...
Installing library DS18B20 0.1.14 to lib/DS18B20 ...
Library DS18B20 0.1.14 installed.
mkdir -p target/
ty/littlefs/littlefs -I../third_party/miniz/miniz -I../platform/MCU/nRF52840/inc -I../dynalib/inc -I../hal/shared -Isrc -I./libraries -Ilib/DS18B20/src -Ilib/OneWire/src -I
. -MD -MP -MF ../build/target/user/platform-13-msrc/test.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -fmessage-length=0 -Wno-error=deprecated-declarations -Wn
o-error=unused-parameter -Wdeprecated-declarations -Wimplicit-fallthrough=2 -Wno-expansion-to-defined -Wno-cast-function-type -Wno-unused-parameter -Wno-error=type-limits -
fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Werror=return-type -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSPARK_PLATFORM_NET=UBLOXSARA -fno-builtin-malloc -fno-builti
n-free -fno-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DUSER_FIRMWARE_IMAGE_SIZE=0x40000 -DUSER_FIRMWARE_IMAGE_LOCATION=0xB4000 -DMODULAR_FIRMWARE
=1 -DMODULE_VERSION=6 -DMODULE_FUNCTION=5 -DMODULE_INDEX=2 -DMODULE_DEPENDENCY=4,1,6201 -DMODULE_DEPENDENCY2=0,0,0 -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""  -fno-excep
tions -fno-rtti -fcheck-new -flto -ffat-lto-objects -DPARTICLE_COMPILE_LTO_FAT -fno-use-cxa-atexit -std=gnu++17 -c -o ../build/target/user/platform-13-msrc/test.o src/test.
cpp
Building cpp file: lib/DS18B20/src/DS18B20.cpp
mkdir -p ../build/target/user/platform-13-mDS18B20/src/
. -MD -MP -MF ../build/target/user/platform-13-mDS18B20/src/DS18B20.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -fmessage-length=0 -Wno-error=deprecated-decla
rations -Wno-error=unused-parameter -Wdeprecated-declarations -Wimplicit-fallthrough=2 -Wno-expansion-to-defined -Wno-cast-function-type -Wno-unused-parameter -Wno-error=ty
pe-limits -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Werror=return-type -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSPARK_PLATFORM_NET=UBLOXSARA -fno-builtin-malloc
-fno-builtin-free -fno-builtin-realloc  -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DUSER_FIRMWARE_IMAGE_SIZE=0x40000 -DUSER_FIRMWARE_IMAGE_LOCATION=0xB4000 -DMODUL
AR_FIRMWARE=1 -DMODULE_VERSION=6 -DMODULE_FUNCTION=5 -DMODULE_INDEX=2 -DMODULE_DEPENDENCY=4,1,6201 -DMODULE_DEPENDENCY2=0,0,0 -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\""
 -fno-exceptions -fno-rtti -fcheck-new -flto -ffat-lto-objects -DPARTICLE_COMPILE_LTO_FAT -fno-use-cxa-atexit -std=gnu++17 -c -o ../build/target/user/platform-13-mDS18B20/s
rc/DS18B20.o lib/DS18B20/src/DS18B20.cpp
In file included from lib/DS18B20/src/DS18B20.h:4,
                 from lib/DS18B20/src/DS18B20.cpp:1:
make[2]: *** [../build/target/user/platform-13-mDS18B20/src/DS18B20.o] Error 1
Am I doing some really silly and wrong to cause these errors? Are there any libraries that are known to compile for a Boron that I can test against to be sure my toolchain is correct? Very frustrating!
Hi @newell, it seems the library is using some calls that are deprecated in Device OS 6+. Please try installing Device OS 5.9.0 and reconfiguring your project for 5.9.0. I am able to get it to compile that way.
Thanks so much for the help! I was also able to confirm it compiles for 5.9.0, so I downgraded the hardware and now it appears to be working.
Still annoyed that the docs show it will compile for 6.
Hi
Having the same problem not sure how to install Device OS 5.9.0 and reconfiguring your project for 5.9.0
Dan
I used "particle update --target 5.9.0" to switch my USB connected Boron to 5.9, then rebuild my firmware with "particle compile boron --target 5.9.0".
No idea if that's the correct process, but I do have a Boron reading a DS18B20 now, and the console shows it's running 5.9, not 6.x.
Hi
Just noticed how to change the OS and Et Voila no compile errors!!! Thanks mucho your inquiry has saved me many hours of debugging!!
Dan
