kyu
1
Hi All,
I have a project that need to talk with BLE, GPS and a control device and all of them use Serial communication.
I was able to use Serial on TX/RX, Serial4 on C2/C3. However I still need another one to talk with.
I tried to use Serial2 but I found it need RGB led being removed.
ParticleSoftSerial I found from here GitHub - ScruffR/ParticleSoftSerial: This library provides a basic implementation of an interrupt timer driven software serial port on any two digital GPIOs as RX/TX. seems not working either.
And I found this article.
Do you think adding a dedicated chip is only solution at this time? What else I can try?
Have you tried the other interfaces mentioned in the docs?
https://docs.particle.io/reference/device-os/firmware/electron/#serial
On what pins did you use it with what baudrate?
kyu
3
Hi @ScruffR,
Oh I didn’t know Serial5 is available on C1, C0 pins.
I just tested it and it works!
Thank you for your advice.
Kyu
