How to turn off Photon wifi manually(without code)
I want to run the code on my photon but I am in a location without wifi. Is there a way to turn off wifi without telling it to do so in the code?
You can’t.
If your application is supposed to be running with or without WiFi, you need to choose a suitable SYSTEM_MODE.
If you haven’t set SYSTEM_MODE or SYSTEM_THREAD(ENABLED) the default is single threaded AUTOMATIC which demands to talk to the cloud before it executes your code.
Thanks @ScruffR . I thought so but wasn’t sure if there was a trick.
I am going to set my Photon to semi-auto mode and that should work.
