Would you mind to help me modify my code with detaCH ADDED?
hERE IS MY CODE:
//Create servo object to control a servo
Servo myServo;
int posCurrent;
void setup()
//Attaches the servo on pin D0 to the servo object
myServo.attach(D0);
posCurrent = 0;
//Register our Particle to control the servo
Particle.function("openBlinds", openBlinds);
Particle.function("closeBlinds", closeBlinds);
void loop()
int openBlinds(String command)
int newPos = command.toInt();
// Make sure it is in the right range
// And set the position
posCurrent = constrain( newPos, 0 , 90);
// Set the servo
myServo.write( posCurrent );
// done
return 1;
int closeBlinds(String command)
posCurrent = constrain( newPos, 90 , 0);
// Set the servo
// done
return 1;
