How to set expiration time on the Access Token
When I go to the settings it says my access token doesn’t expire. I would like to expire in 90 days. How do I do this?
A docs search would’ve come up with this
https://docs.particle.io/reference/api/#generate-an-access-token
For now you have to do it using the API, the docs have a copy paste example though as @ScruffR linked :slight_smile:
