Hi everyone,
my Photon connects to a server in my home network and authenticates with username and password. That works really reliable so far. To be able to send commands to the server I need to be able to read the response headers because the server sends some kind of cookie token. The httpclient library does not support Serial.println(response.headers). Is there a simple solution for this?
#include "HttpClient.h"
* Declaring the variables.
unsigned int nextTime = 0; // Next time to contact the server
HttpClient http;
http_header_t headers[] = {
{ "Content-Type", "application/json" },
{ "Accept" , "application/json" },
{ "x-elocs-username" , "some username" },
{ "x-elocs-password" , "some password hash" },
{ NULL, NULL } // NOTE: Always terminate headers with NULL
http_request_t request;
http_response_t response;
if (nextTime > millis()) {
return;
Serial.println();
Serial.println("Application>\tStart of Loop.");
// Request path and body can be set at runtime or at setup.
request.hostname = "some ip";
request.port = 80;
request.path = "/login";
// The library also supports sending a body with your request:
//request.body = "{\"key\":\"value\"}";
// Post request
http.post(request, response, headers);
Serial.print("Application>\tResponse status: ");
Serial.println(response.status);
Serial.print("Application>\tHTTP Response Body: ");
Serial.println(response.body);
nextTime = millis() + 10000;
In my Browser it looks like this:
Code Details
200
Response body
HOME
Response headers
connection: keep-alive content-length: 8 content-type: text/html; charset=utf-8 date: Sun, 31 Mar 2019 09:04:23 GMT etag: W/"8-cb36de7c" x-elocs-language: de x-elocs-token: here is the access token x-elocs-version: 1.8.22189.xxx x-powered-by: Express
In the serial console i receive:
Start of Loop.
Application> Response status: 200
Application> HTTP Response Body: HOME
