Sorry about that. I am trying to keep this all organized. Regardless, I am back working again. [quote="bloukingfisher, post:60, topic:26497"]
So it looks like the RX is receiving everything? And it also returns an ACK so the TX should know that the message went through
[/quote]
Yes, I would agree. I am confused by Failed to Send on the TX side. What is that telling me? Why am I only getting occasional Ok, send with retry? Again, what is that telling me?
I made the changes to the RX code, flashed it and no real difference that I see. Here is a copy of RX serial and you can see where I reset the TX board
Again, swap the RX and TX hardware. It looks like the TX side is having an issue with receiving, but yet sending fine. You want to test and make sure both can units can receive equally well.
Add code to the TX side to print out the RSSI of the ACK that it seems to receive 1/10 times. The RSSI strength should very closely match the RSSI the RX is reporting. But if it is much lower (say RX reports -52 or -86 and TX reports -96 or -110) it’s telling you the TX unit is not receiving the way it should.
Well this is getting a bit above me but here is what I attepted with adding the RSSI portion to the TX code
Serial.print("."); //THis gives us a neat visual indication of time between messages received
char radiopacket[20] = "Hello Photon #";
itoa(packetnum++, radiopacket+13, 10);
Serial.print("Sending "); Serial.println(radiopacket);
//send the message
// Uncomment below and comment out above if you want to send with retry (which will look for an ACK message or resends)
if (radio.sendWithRetry(RECEIVER, radiopacket, strlen(radiopacket))) { //target node Id, message as string or byte array, message length
Serial.println("OK, sent with retry");
else
Serial.println("Failed to send");
//send message to Particle console if not using serial
String TXMessage = "[NODE: " + String(NODEID) + "] " + String(radiopacket) + " ";
Particle.publish("Message transmitted",TXMessage,360,PRIVATE);
radio.receiveDone(); //put radio in RX mode
//print message received to serial
Serial.println(" ");
Serial.print('[');Serial.print(radio.SENDERID);Serial.print("] ");
Serial.print((char*)radio.DATA);
Serial.print(" [RX_RSSI:");Serial.print(radio.RSSI);Serial.print("]");
String RXMessage = "[" + String(radio.SENDERID) + "] " + String((char*)radio.DATA) + " [RSSI: " + String(radio.RSSI) + "]";
Particle.publish("Message received",RXMessage,360,PRIVATE);
delay(2000); //wait 2 seconds between transmits
} //end loop
If that is correct, then my TX board is not RX at all because I am seeing [RX_RSSI:0]
Changed roles on the hardware and the results are the same.
Thank you
OK, with hardware swapped with the same result that minimizes a hardware issue.
Because with failed to send you never received an ACK you also will not have an RSSI, thus the 0. You will need to look for the odd “OK, sent with retry” to see if it reports the RSSI.
Maybe try the example code from the Sparkfun link (with the correct #include for particle libraries), or example code from RadioHead examples. I know the code worked for me (primarily on non-HW versions, although I briefly tested 1 HW unit on the TX side but may not have used sendWithRetry).
Do me a favor if you can - comment out all the particle publish lines from both RX and TX and test again.
My lack of getting radio modules to work is taking me up the ladder to increasingly more expensive modules! Do you have a link to an RFM95w you would recoomend? The other to note is that I would eventlually like to run these radios on a system that uses an Electron with xyz radio as a server and up to 6 pro mini’s with xyz radio as nodes. Cost is important of course but making a reliable system is also important
Thanks @RWB
Not really a surprise that this throws an error since there actually is no A7 pin on Gen3 devcies.
The fact that it was compiling on 0.9.0 just shows that the non-existend pin was nevertheless “defined” which now got corrected.
This is the code part in question which should be filed as a GitHub issue in the library repository
Thanks. I modified manually the library, and it compiles.
However the board initialisation fails and return FALSE. I can successfully read the registers using the library RFM69::readAllRegs() and they are all to default value. It seems I can’t write, but I can read. I wonder if I missed something.
For more context, I am trying to read the RF messages send by an EmonTX from a Xenon, through an RFM69HCW.
I've updated that code in the repository. Thanks @ScruffR for determining that. I've not tested the change or worked with this hardware for a long time so unfortunately can't be of more help @Fabien
I apologize for even asking, being that you’re saying that you haven’t been using the hardware in some time (I’m interested in what you moved on to), but do you remember which version of the Lowpowerlab arduino library you were using when you had success on post #16? I have really struggled and have tried multiple platforms (Uno, Pro Mini, even Moteino) and none have successfully sent a message to my Photon (running the hello-photon-rx-rfm69 example).
My use case requires wireless battery-powered sensors and I’m just exhausted with trying to figure this out.
I don’t think there’s a library version number from Lowpowerlab. However, what was working for Photon is in my repository.
Have you tested Photon to Photon transmission/receive? That will at least confirm that your radios are wired up correctly and code is working between the 2 photons.
But I would first try to make sure you can do Photon to Photon. Plus, Felix and the community have updated that library significantly in the interim so for the Arduino side I would try the latest before falling back on this version (or try this and if it works, switch to the latest version…)
Also, post your serial output or other troubleshooting information which would make it easier to suggest approaches to get it working.
@benbarnard FYI I moved onto an Anaren module which is FCC certified. It is 5X the cost of RFM69 but incorporating it in my commercial planned product saves future hassle around FCC certification.
I actually only own one Photon, so I will order a second to confirm that the wiring is correct. I’m positive I’ll find a use for it anyway. I will start over with your advice and report back - again, thank you for being so generous with your time.
Anaren looks very interesting! Do you use this Atmosphere IDE that I’m seeing? Looks very different than Arduino.
