Thanks guys. This library is working great when communicating between Photons. Has anyone tried setting up a Photon with the RFM69 as a receiver and an arduino pro mini with RFM69 as a transmitter? I am trying to have them both communicate with each other and unfortunately the Photon is not able to receive any messages from the Arduino pro mini. Below are my codes for each device. Has anybody had any success with getting the Photon and Arduino to communicate with each other?
Arduino Pro Mini Code
#include <RFM69.h>
#include <RFM69_ATC.h>
#include <RFM69registers.h>
#include <SPI.h>
int16_t NETWORKID = 0;
int16_t MYNODEID = 9;
int16_t TONODEID = 3;
//#define NETWORKID 0 // Must be the same for all nodes
//#define MYNODEID 1 // My node ID
//#define TONODEID 3 // Destination node ID
#define FREQUENCY RF69_915MHZ
//#define USEACK true // Request ACKs or not
#define LED 6 // LED positive pin
#define GND 8 // LED ground pin
#define BTN 7
RFM69 radio;
void setup()
Serial.begin(9600);
Serial.print("Node ");
Serial.print(MYNODEID,DEC);
Serial.println(" ready");
pinMode(BTN, INPUT);
pinMode(GND,OUTPUT);
digitalWrite(GND,LOW);
radio.initialize(FREQUENCY, MYNODEID, NETWORKID);
radio.setHighPower(); // Always use this for RFM69HCW
void loop()
if(digitalRead(BTN) == HIGH){
Serial.print("begin - pushed");
static int sendlength = 8;
static char sendbuffer[] = "411";
Serial.print("sending to node ");
Serial.print(TONODEID, DEC);
Serial.print(", message [");
for (byte i = 0; i < sendlength; i++)
Serial.print(sendbuffer[i]);
Serial.println("]");
// if (USEACK)
// if (radio.sendWithRetry(TONODEID, sendbuffer, sendlength))
// Serial.println("ACK received!");
// else
// Serial.println("no ACK received");
// else // don't use ACK
// radio.send(TONODEID, sendbuffer, sendlength);
sendlength = 8; // reset the packet
Photon Code
#include "RFM69-Particle/RFM69-Particle.h"
#include "RFM69-Particle/RFM69_ATC.h"
#include "RFM69-Particle/RFM69registers.h"
// Adjustments to library to work with Particle Photon including in Web IDE by Jurie Pieterse
// Forked library for Photon at https://github.com/bloukingfisher/RFM69/
// Serial NOT required to confirm working - you can watch your Particle Console logs!
/* RFM69 library and code by Felix Rusu - felix@lowpowerlab.com
// Get libraries at: https://github.com/LowPowerLab/
// Make sure you adjust the settings in the configuration section below !!!
// Copyright Felix Rusu, LowPowerLab.com
// Library and code by Felix Rusu - felix@lowpowerlab.com
// License
// This program is free software; you can redistribute it
// and/or modify it under the terms of the GNU General
// Public License as published by the Free Software
// Foundation; either version 3 of the License, or
// (at your option) any later version.
// This program is distributed in the hope that it will
// be useful, but WITHOUT ANY WARRANTY; without even the
// implied warranty of MERCHANTABILITY or FITNESS FOR A
// PARTICULAR PURPOSE. See the GNU General Public
// License for more details.
// You should have received a copy of the GNU General
// Public License along with this program.
// If not, see <http://www.gnu.org/licenses></http:>.
// Licence can be viewed at
// http://www.gnu.org/licenses/gpl-3.0.txt
// Please maintain this license information along with authorship
// and copyright notices in any redistribution of this code
// *********** IMPORTANT SETTINGS - YOU MUST CHANGE/CONFIGURE TO FIT YOUR HARDWARE *************
int16_t NETWORKID = 0; //the same on all nodes that talk to each other
int16_t NODEID = 3;
//Match frequency to the hardware version of the radio on your Feather
//#define FREQUENCY RF69_433MHZ
//#define FREQUENCY RF69_868MHZ
//#define ENCRYPTKEY "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
#define IS_RFM69HCW false // set to 'true' if you are using an RFM69HCW module
#define RFM69_CS A2
#define RFM69_IRQ 2
#define RFM69_IRQN 2 //On Photon it is the same unlike Arduino
#define RFM69_RST 6
int16_t packetnum = 0; // packet counter, we increment per xmission
RFM69 radio = RFM69(RFM69_CS, RFM69_IRQ, IS_RFM69HCW, RFM69_IRQN); //initialize radio with potential custom pin outs; otherwise you may use for default: RFM69 radio;
// *********** Wiring the RFM69 Radio to Photon *************
/* Arduino wiring provided for reference, color
Photon Arduino RFM69 Color
GND GND GND Black
3V3 3.3V VCC Red
A2 10 NSS Yellow
A3 13 SCK Green
A5 11 MOSI Blue
A4 12 MISO Violet
D2 2 DI00 Gray
ANA Antenna
D6 RST Optional
void setup()
Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
Particle.publish("RFM69 RX Startup setup","Completed",360,PRIVATE);
Particle.publish("WiFi signal",String(WiFi.RSSI()),360,PRIVATE);
Serial.println("RFM69 Based Receiver");
// Hard Reset the RFM module - Optional
pinMode(RFM69_RST, OUTPUT);
digitalWrite(RFM69_RST, HIGH);
delay(100);
digitalWrite(RFM69_RST, LOW);
delay(100);
// Initialize radio
radio.initialize(FREQUENCY,NODEID,NETWORKID);
if (IS_RFM69HCW) {
radio.setHighPower(); // Only for RFM69HCW & HW!
// To improve distance set a lower bit rate. Most libraries use 55.55 kbps as default
// See https://lowpowerlab.com/forum/moteino/rfm69hw-bit-rate-settings/msg1979/#msg1979
// Here we will set it to 9.6 kbps instead
radio.writeReg(0x03,0x0D); //set bit rate to 9k6
radio.writeReg(0x04,0x05);
radio.setPowerLevel(10); // power output ranges from 0 (5dBm) to 31 (20dBm)
// Note at 20dBm the radio sources up to 130 mA!
// Selecting a power level between 10 and 15 will use ~30-44 mA which is generally more compatible with Photon power sources
// As reference, power level of 10 transmits successfully at least 300 feet with 0% packet loss right through a home, sufficient for most use
//radio.encrypt(ENCRYPTKEY);
Serial.print("\nListening at ");
Serial.print(FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
Serial.println(" MHz");
radio.receiveDone(); //put radio in RX mode
//=========================MAIN LOOP===========================================
Serial.print("."); //THis gives us a neat visual indication of time between messages received
//check if something was received (could be an interrupt from the radio)
if (radio.receiveDone())
//print message received to serial
Serial.println(" ");
Serial.print('[');Serial.print(radio.SENDERID);Serial.print("] ");
Serial.print((char*)radio.DATA);
Serial.print(" [RX_RSSI:");Serial.print(radio.RSSI);Serial.print("]");
//send message to Particle console if not using serial
String RXMessage = "[" + String(radio.SENDERID) + "] " + String((char*)radio.DATA) + " [RSSI: " + String(radio.RSSI) + "]";
Particle.publish("Message received",RXMessage,360,PRIVATE);
//check if received message contains Hello
if (strstr((char *)radio.DATA, "Hello"))
//check if sender wanted an ACK
if (radio.ACKRequested())
radio.sendACK();
Serial.println(" - ACK sent");
else {Serial.println(" - No ACK sent");}
delay(1000);
} //end loop
Thanks in advance for the help guys!
