Sorry, I should have explained.
I’m saving anything to EPROM. Here is the where that is used
char dev_name[32];
String deviceName;
void loop{
alertPowerSms = String::format("{\"Name\": \"%s\", \"To\": \"%s\"}", deviceName.c_str(), setPhoneString.c_str());
I did try 10 seconds the most but I will try to extend that even further. Its just odd that it will work right away if I do a hard shutdown.
How would you try to write a String to EEPROM?
You cannot use EEPROM.put() with String.
And instead of having an intermediate deviceName why not directly use dev_name?
Like this
char dev_name[32];
char phone_str[32];
char alertPowerSms[128];
snprintf(alertPowerSms, sizeof(alertPowerSms)
, "{\"Name\": \"%s\", \"To\": \"%s\"}"
, dev_name
, phone_str
I wasn’t planning on saving as a String.
I’ll remove the intermediate deviceName. Did you think that us the issue?
No dice ... same results.
