I’ve been trying to subscribe to events from my Photon using python, but I’m having some trouble.
Code on my photon is the standard “publish and dashboard with photoresistors” sketch.
Using curl works
curl -H "Authorization: Bearer {ACCESS_TOKEN_GOES_HERE}" \
https://api.particle.io/v1/events/motion-detected
Yields results like
event: motion-detected
data: {"data":"intact","ttl":"60","published_at":"2015-06-25T05:08:22.136Z","coreid":"coreid"}
data: {"data":"broken","ttl":"60","published_at":"2015-06-25T05:08:23.014Z","coreid":"coreid"}
But I can't get the same to work using requests
However, I’ve tried using requests:
address3 ='https://api.particle.io/v1/events/beamStatus'
data = {'Authorization': 'Bearer {ACCESS_TOKEN_GOES_HERE}'}
r3 = requests.get(address3, headers=data)
And I get nothing.
So, then I took a look at : Subscribe to spark events using python
and tried :
from sseclient import SSEClient
messages = SSEClient('https://api.spark.io/v1/events?access_token={acces-token-goes-here}')
for msg in messages:
print(str(msg).encode('utf-8'))
And I get a response, but it’s weird, like it’s not from my Photon
{"data":"b:-3;rb:41;d:0;rd:73;mo:0;m:2022;h:1932;c:2105;l:0","ttl":"60","published_at":"2015-06-27T20:15:08.802Z","coreid":"53ff6a066667574853222067"}
{"data":"75.65","ttl":"60","published_at":"2015-06-27T20:15:08.893Z","coreid":"53ff6e066667574836061267"}
{"data":"{ \"s\":\"wthr\", \"u\":\"F\",\"l\":\"Houston, TX\",\"m\":\"Temperature\",\"o\":\"DXHackers\",\"g\":\"10000000-0000-0000-0000-000000000001\",\"v\": 71.599998,\"d\":\"Paul Office\" }","ttl":"60","published_at":"2015-06-27T20:15:08.941Z","coreid":"54ff6d066672524844560167"}
{"data":"{ \"s\":\"wthr\", \"u\":\"%\",\"l\":\"Houston, TX\",\"m\":\"Humidity\",\"o\":\"DXHackers\",\"g\":\"10000000-0000-0000-0000-000000000001\",\"v\": 39.000000,\"d\":\"Paul Office\" }","ttl":"60","published_at":"2015-06-27T20:15:08.946Z","coreid":"54ff6d066672524844560167"}
{"data":"{\"Hours\": 11, \"Minutes\": 21, \"Seconds\": 57}","ttl":"60","published_at":"2015-06-27T20:15:09.020Z","coreid":"54ff6a066678574941340667"}
{"data":"{\"Watt1\":2289, \"Watt2\": 1576, \"Watt3\": 1887}","ttl":"60","published_at":"2015-06-27T20:15:09.024Z","coreid":"54ff6a066678574941340667"}
{"data":"Light: 255","ttl":"60","published_at":"2015-06-27T20:15:09.047Z","coreid":"53ff6d065067544820560587"}
Traceback (most recent call last):
File "<stdin>", line 2, in <module>
UnicodeEncodeError: 'ascii' codec can't encode characters in position 27-28: ordinal not in range(128)
Is that something I should expect? It doesn’t look like it’s talking to my photon?!
Other than that weirdness, what’s the best way to subscribe to these private published events from the spark?
