How to do simplest multithreading task operation
I use photon. I would like to use the simplest multithreading task operation (not timer). Because my delay() operations are stopping the flow of the program.
For example;
Void simple_function () {
DigitalWrite (D1, HIGH);
Delay (5,000);
DigitalWrite (D1, LOW);
I want to handle this function as multithreading, and most IMPORTANT I need to put back the space used in the RAM after I finish using it.
for one sure there are more
Yes i tried and tried it. But I can not undo the RAM I am using. This consumes the RAM after several uses and the device is locked. Do I need another way or should I be able to reclaim the used ram?
@pusent, threads cannot be destroyed on Particle devices. You should be using an Software Timers or a non-blocking FSM (finite state machine) in loop() to implement your controls.
I understood thank you. I try to find another way.
@pusent, don’t hesitate to ask for assistance:wink:
Well, how the simplest case, the FSM?
@pusent, if you use a software Timer set for 1 second “ticks” that will be the basis for your timed GPIO transition. You simply need to have a flag to indicate a start of sequence which will be looked at in the timer callback. Something like this:
#define WAIT  0
#define ON    1
#define OFF   2
Timer timer(1000, control_pin);
volatile int pin_state;
void control_pin() {   // This gets called by the Software Timer every 1000ms
  static on_time;
  switch(pin_state) {
    case WAIT:   // waiting for an ON command so do nothing and exit
      break;
    case ON:      // Now in ON state so set pin HIGH and reset ON timer
      digitalWrite(D1, HIGH);
      on_time = 4;  // It will take 1 sec to get to next state so only count down 4 more secs
      pin_state = OFF;  // change the state for the next pass
      break;
    case OFF:   // Count down the on_time.  Exit if not at zero
      if (--on_time > 0)  // 4 secs have not elapsed yet so exit
        break;
      digitalWrite(D1, LOW);
      pin_state = WAIT;  // cycle complete, reset FSM to wait for next start
      break;
// ... other code
pin_state = WAIT;
timer.start();
// ... other code
// Set FSM pin_state to ON to start the cycle.  First check that FSM in not in a cycle already.
  if (pin_state == WAIT)  // Could also loop waiting for WAIT
    pin_state = ON;
This example can simplified but I wrote it so you could (hopefully) understand how the FSM and timer work. The timer could be made much smaller since, as it stands, the pin won’t change states for up to 1 second. If you make it 1 ms, then on_time needs to be changed to the value necessary for 5 secs - 1ms or 4999.
The same approach can be taken using a non-blocking millis() timer in loop(), stepping through each state like what is done in the timer.
Owww… nice example for me. thanks alot
yeah that’s a good example. thank you @peekay123
