I want to make a library (v2) of a library where the example includes *.h file.
Partivle Dev and CLI can’t compile it.
Uploaded to webIDE as a private library but it lists “usage” and “data.h” as seperate example files.
I used particle library create to populate the initial structure:
@ScruffR Thanks for the suggestion. Here's the output:
C:\Users\doan\tech\tcon_mpico>particle compile p examples/usage
Compiling code for p
Including:
examples\usage\hello_world.h
examples\usage\usage.ino
Compile failed. Exiting.
usage.cpp:3:24: fatal error: tcon_mpico.h: No such file or directory
// Example usage for mpico library by Michael Doan.
C:\Users\doan\tech\tcon_mpico>particle compile p examples/usage/hello_world.h
Including:
library.properties
src\tcon_mpico.h
src\tcon_mpico.cpp
downloading binary from: /v1/binaries/58cd547dffa8bc3235f51a4e
saving to: p_firmware_1489851510651.bin
Memory use:
text data bss dec hex filename
4476 8 1424 5908 1714
Compile succeeded.
I can't do the same for usage.ino because it doesn't find hello_world.h. Putting both files in the compile command line results in the same fail signature as the first attempt in this experiment.
What does work is if I move hello_world.h to the SRC directory. However, that doesn't seem ideal since I'd want library users to load their own data file and not have to carry this example around with their code.
I have already proposed the addition of a project.properties file for library examples to allow for more complex samples a while back.
And @jvanier said to consider it, but can’t promise anything let alone give a timeline.
