Hello,
I declared MQTT client(“broker”, port,callback,512); in .ino file and want to use same instance in .cpp file for some process.
is it possible to use the same instance or I have to open again a new connection to use in the .cpp file?
Hello,
You’d need to define an extern object variable of the same name in your external module (e.g. .cpp)
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
