I’m not a die-hard programmer, therefore I would like to asked you for some advice.
With my Photon I’ve made a lighting system in my room with a lot of ws2812’s and my phone. Very cool of course ^.^
I would like it turn on at 8 O’clock in the morning. So with if(Time.hour() == 8) { that happens.
Only, I don’t want my Photon to be on the whole night. Luckily there for System.sleep(SLEEP_MODE_DEEP,60); exists were ‘60’ is the time it has to be in sleep mode seconds.
I want my photon to go to sleep when I press the ‘sleep’ button on my phone and wake up at, lets say, 7’oclock.
But I don’t turn off my light at the same time every day. So the ‘sleep mode seconds’ has to be a variable.
My question: any good advice on how I can calculate the remaining time from the moment I press the ‘sleep’ button till 7 o’clock witch can be filled in instead of the ‘60’?
Hmm, a very low key solution would be to calculate it (untested code).
int mins = 60 - Time.minute(); //Minutes left in current hour.
var hour = Time.hour();
//Add one hour since we added the remaining minutes already
if (hour == 23) hour=0;
else hour++;
if (hour > 7)
mins += (24-hour) * 60 + (7*60);
} else {
mins += (7-hour) * 60;
//sleep for mins * 60
Alternatively you could wake up every x minutes and check the time, but energywise its not great, and if the onboard led is visible it will distract.
Hint:
The clock works in seconds since Jan 1st(?), 1970. Its called Epoch or Unix time.
You can calculate the future ‘Wake Time’ in seconds since 1970.
You can measure the time that the device goes to 'Sleep".
‘Wake Time’ - ‘Sleep Time’ = Sleep timer in seconds.
By using the seconds directly, you avoid rolling over dates.
The real question is how to calculate the number of seconds between now() and futureTime().
Hi, Thanks for your input.
Sadly, I haven’t succeeded yet. It’s somewhat more complicated than I thought ^^
Moreover, i get the following error when I just add “System.sleep(SLEEP_MODE_DEEP,60);” to my (or any) code. Without my code verify just fine.
*In file included from ../inc/spark_wiring.h:29:0,*
*from ../inc/application.h:29,*
*from mijnpijl.cpp:8:*
*../../core-common-lib/SPARK_Firmware_Driver/inc/config.h:12:2: warning: #warning "Defaulting to Release Build" [-Wcpp]*
*#warning "Defaulting to Release Build"*
*mijnpijl.cpp: In function 'void loop()':*
*mijnpijl.cpp:56:11: error: 'class SystemClass' has no member named 'sleep'*
