I’m sorry if this is common knowledge
I’d like to use the mfcc of the CMSIS-DSP library, but I see it’s not included in what is installed with Workbench.
Can I include a more recent version of the library including mfcc, and in that case - where do I find instructions for doing this?
I’ve tried a couple of things, but it seems Workbench insists on using the older version.
CMSIS-DSP is installed in your user directory with particle Workbench:
”user_dir”\.particle\toolchains\deviceOS\6.3.3\third_party\ambd_sdk\ambd_sdk\component\soc\realtek\amebad
You need to mix the .c and .h files into a single src directory, in a directory, in lib. The structure is described here.
I'm still not positive it will override the SDK, but it's worth a try.
I'm pretty sure you'll also run into a problem because .a file (precompiled static library) can't be included in a normally compiled user firmware binary, and I think CMSIS has one.
