How can i find my APN for Particle sim
I am reading tutorials about GPS tracking, all i see on the internet they use Hologram SIM to work…so the code
is build for Hologram SIM’s, however if i can get Partilce APN and replace it in there code that i find
will save me alot of time.
IIRC, the APN for Particle SIMs is broadband but I’ll double check (update: seems to work)
However, since Particle uses multiple providers world wide, you may need to select an alternative one
Here is a list of possible default APNs used per country/region
I will try this APN and tell you my results, i am live in UAE…it should work
thank you for your help
