I am attempting to use particle publish and subscribe to link 2 photons. I have one with a pir sensor and it uses particle publish
Here is the code from the one with the pir sensor
int pir = 0;
pinMode(D7, OUTPUT);
pinMode(D4, INPUT);
pir = digitalRead(D4);
if(pir == HIGH )
digitalWrite(D7, HIGH);
Particle.publish("Motion Detected", "True");
delay(5000);
else{
digitalWrite(D7, LOW);
// And repeat!
I am having trouble understanding particle subscribe. How can I have a second photon subscribe to light up D7 when the first photon publishes “True”
I already RTFM so no need to refer to it. Unfortunately I am still struggling as I am still learning.
If I had some more/better examples I might be able to deconstruct and understand.
You could add an unconditional Serial.println(data) statement in your handler and see what happens with your handler:
if it gets called at all
what the data parameter contains
if you get into any of your conditional branches
why not
And just to clarify const char* strings are not compared that way. That’d only work for String objects.
For C strings you’d use something like if (!strcmp(data, "True")
The == operator used that way would only check if the const char* of data points to the same memory location as the respective string literal - which it never will, since one will be in RAM while the other always sits in flash memory.
Particle.subscribe("Motion Detected", motionFunction);
void motionFunction(const char *event, const char *data)
if (strcmp(data,"True")==0) {
// if your buddy's beam is intact, then turn your board LED off
digitalWrite(D7,LOW);
else if (strcmp(data,"False")==0) {
// if your buddy's beam is broken, turn your board LED on
Serial.println(data);
You intend to have D7 not lit in both cases?
How are you checking the serial output?
Can you double check the exact event name?
You could also use the prefix filter feature of subscribe and only subscribe to a shorter part of the event name.
Try this then
Serial.begin(115200);
Particle.subscribe("Motion", motionFunction);
static uint32_t ms;
if (millis() - ms > 1000)
ms = millis();
Serial.print("."); // to see if you get serial output at all
Serial.printf("\r\n%s: \"%s\"\r\n", event, data);
digitalWrite(D7, !digitalRead(D7)); // toggle D7 led on each subscribe firing
RGB.control(true);
RGB.color(255, 128, 0); // set RGB LED amber
RGB.control(false); // reestablish default RGB function
