There part I’m specifically confused about is the getAcceleration function. Why are we dividing the ADC_REF with the ADC_Amplitude ? I’m guessing in the spark core it would be 3.3V/4096 ? What is the ZERO_X, ZERO_Y and ZERO_Z. and what role does the sensitivity play ?
// Function: Cpp file for ADXL335
// Hardware: Grove - 3-Axis Analog Accelerometer
// Arduino IDE: Arduino-1.0
// Author: FrankieChu
// Date: Jan 10,2013
// Version: v1.0
// by www.seeedstudio.com
// This library is free software; you can redistribute it and/or
// modify it under the terms of the GNU Lesser General Public
// License as published by the Free Software Foundation; either
// version 2.1 of the License, or (at your option) any later version.
// This library is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
// Lesser General Public License for more details.
// You should have received a copy of the GNU Lesser General Public
// License along with this library; if not, write to the Free Software
// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include <Arduino.h>
#include "ADXL335.h"
void ADXL335::pinsInit()
pinMode(X_AXIS_PIN, INPUT);
pinMode(Y_AXIS_PIN, INPUT);
pinMode(Z_AXIS_PIN, INPUT);
void ADXL335::begin()
pinsInit();
scale = (float)SENSITIVITY*ADC_AMPLITUDE/ADC_REF;
void ADXL335::getXYZ(int16_t *x,int16_t *y,int16_t *z)
*x = analogRead(X_AXIS_PIN);
*y= analogRead(Y_AXIS_PIN);
*z = analogRead(Z_AXIS_PIN);
void ADXL335::getAcceleration(float *ax,float *ay,float *az)
int x,y,z;
float xvoltage,yvoltage,zvoltage;
getXYZ(&x,&y,&z);
xvoltage = (float)x*ADC_REF/ADC_AMPLITUDE;
yvoltage = (float)y*ADC_REF/ADC_AMPLITUDE;
zvoltage = (float)z*ADC_REF/ADC_AMPLITUDE;
Serial.println("voltage:");
Serial.println(xvoltage);
Serial.println(yvoltage);
Serial.println(zvoltage);
*ax = (xvoltage - ZERO_X)/SENSITIVITY;
*ay = (yvoltage - ZERO_Y)/SENSITIVITY;
*az = (zvoltage - ZERO_Z)/SENSITIVITY;
</pre>
<pre> /*****************************************************************************/
// Function: Header file for ADXL335
// Version: v1.0
#ifndef __ADXL335_H__
#define __ADXL335_H__
/*macro definitions of Analog read pins*/
#define X_AXIS_PIN A0
#define Y_AXIS_PIN A1
#define Z_AXIS_PIN A2
#define ADC_AMPLITUDE 1024//amplitude of the 10bit-ADC of Arduino is 1024LSB
#define ADC_REF 5 //ADC reference is 5v
#define ZERO_X 1.22 //accleration of X-AXIS is 0g, the voltage of X-AXIS is 1.22v
#define ZERO_Y 1.22 //
#define ZERO_Z 1.25 //
#define SENSITIVITY 0.25//sensitivity of X/Y/Z axis is 0.25v/g
class ADXL335
private:
void pinsInit();
float scale;
public:
void begin();
void getXYZ(int16_t *x,int16_t *y,int16_t *z);
void getAcceleration(float *ax,float *ay,float *az);
#endif
