Hi peekay
in the evening, i may post a picture, but for short - i use the 3V output from the photon on the Vcc input of the adafruit PCA9685 Board. This worked fine with my Huzzah instead of the phtoton.
Hi peekay
@T-I, so you power the PCA9685 (Vcc) via the 3V3 pin of the Photon. And you have pull-up resistors to 3V3? How do you power the LEDs? Do you have any other I2C devices connected?
Try connecting the PCA9685 (I2C and pullups) with NO LED power to V+. Then run an I2C scanner app like this one to see if the PCA can be discovered:
// i2c_scanner
// http://playground.arduino.cc/Main/I2cScanner
// Version 1
// This program (or code that looks like it)
// can be found in many places.
// For example on the Arduino.cc forum.
// The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
// Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26 2013
// V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
// by Arduino.cc user Krodal.
// Changes by louarnold removed.
// Scanning addresses changed from 0...127 to 1...119,
// according to the i2c scanner by Nick Gammon
// http://www.gammon.com.au/forum/?id=10896
// Version 5, March 28, 2013
// As version 4, but address scans now to 127.
// A sensor seems to use address 120.
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include "application.h"
Wire.begin();
while(!Serial.available()) Particle.process(); // Hit a key to start
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknow error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
else
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
If nothing is discovered, try powering the PCA via the Photon Vin or the 5V supply with pullup going to that supply. Then try scanning again.
Hi Peekay,
thanks a lot!
I did not expect to need the pullup-resistors. Added them and voila - the photon sees my PCA-board.
With this result, i may continue.
For the big picture - i start a little homebrew project with lifx compatible LED-Stripe lighting. I“ll post results, when it is presentable
Kind regards to all.
Hi T-I
Sorry Iām really new to all of this I was looking at using one of the adafruit PCA9685ās and a Photon.
Would you have a schematic or some pics of how it needs to be wired up. Sorry Iām not sure what the pull up resistors do in this case?
Did people end up needing a logic level controller or the like⦠I read that the PCA9685 can run at 3.3v and then you could run external power to the servo powerā¦
I was hoping to drive multiple servos using the Photon and am trying to read as much as I can and ask to see how to start even with the simple wiring
Hi thomen,
for me it was also not obvious, but the Api-documentation says:
Connect a pull-up resistor(1.5k to 10k) on SDA line. Connect a pull-up resistor(1.5k to 10k) on SCL line.
So i did. I hooked sdl and sda via a 7.4k resistor to the 3v pin AND to the corresponding pins on the PCA board.
Thanks for letting me know that makes sense⦠Have you managed to get this driving a few servos yet? Iād love to know what the code looks like to communicate with it rather than a standard servo call straight off the photon⦠Is it very different?
Well, for me, that was the first step. As i wrote, id like to drive LEDs no servos. Thus, i cant provide help concerning that. But in the public libraries, a saw a PCA lib, that addresses servos. Did you try that?
