Has anyone had success hooking up an SD card to the Photon and writing/reading data?
If you hit the SHOW RAW button in Web IDE when you see the error, you’ll find out that it is related to this line
  if (!sd.begin(chipSelect, SPI_HALF_SPEED))
You should be able to use SPI_FULL_SPEED instead, but if that produces communication errors you can use SD_SCK_HZ(4 * MHZ) instead of SPI_HALF_SPEED.
Thanks it compiled successfully!
