Hello,
I use a self-made NTP client, based on a timer controlled state machine on my Argon and it seems that this client will produce a hard fault after one cycle (should be error code 1 when I see it right).
NTP Server("pool.ntp.org");
Server.SetCallback(NTP_Callback);
Server.Start();
NTP::NTP(const char* Server) : _mUpdateTimer(Timer(20, &NTP::_run, *this))
this->_init(Server, NTP_DEFAULT_PORT, NTP_DEFAULT_TIME, NTP_DEFAULT_TIMEOUT, NULL);
void NTP::Start(void)
this->_mState = STATE_SEND_PACKET;
this->_mUpdateTimer.start();
void NTP::SetCallback(NTP::NTP_Callback Callback)
this->_mCallback = Callback;
void NTP::_run(void)
switch(_mState)
case STATE_SEND_PACKET:
Serial1.println("A");
this->_mError = INVALID_TIME;
// Change back to the fast update time
this->_mUpdateTimer.changePeriodFromISR(20);
// Prepare the package
memset(&this->_mPacket, 0x00, sizeof(NTP::NTP_Packet));
this->_mPacket.VN = NTP_VERSION & 0x07;
this->_mPacket.Mode = CLIENT;
// Request a new package from the server
this->_mClient.begin(this->_mPort);
this->_mClient.beginPacket(this->_mServer, this->_mPort);
this->_mClient.write((const uint8_t*)&this->_mPacket, sizeof(NTP::NTP_Packet));
this->_mClient.endPacket();
this->_mSendTime = millis();
this->_mState = STATE_WAIT_RESPONSE;
break;
case STATE_WAIT_RESPONSE:
if(!this->_mClient.parsePacket())
if(millis() > (this->_mSendTime + this->_mTimeout))
this->_mState = STATE_TIMEOUT;
return;
this->_mClient.read((unsigned char*)&this->_mPacket, sizeof(NTP::NTP_Packet));
this->_mClient.stop();
this->_mRecTime = millis();
this->_mState = STATE_GET_TIME;
break;
case STATE_GET_TIME:
Serial1.println("C");
// Swap the endianess of the 32 bit fields
for(uint8_t i = 0x01; i < (sizeof(NTP::NTP_Packet) / 0x04); i++)
*(((uint32_t*)(&this->_mPacket)) + i) = __SWAP32__(*(((uint32_t*)(&this->_mPacket)) + i));
if(this->_mPacket.Strat == 0x00)
return;
uint32_t ServerPoll = this->_power(2, this->_mPacket.Poll);
if((this->_mUpdateTime / 60) < ServerPoll)
this->_mUpdateTime = ServerPoll;
// Ignore the time before the 01/01/1970
this->_mPacket.TransmitTimestamp_S -= 2208988800UL;
// Get the milliseconds
this->_mMillis = (uint32_t)(((double)this->_mPacket.TransmitTimestamp_F) / 0xFFFFFFFF * 1000);
// Add the routing delay for the communication with the server
this->_mMillis += this->_mRecTime - this->_mSendTime;
if(this->_mMillis >= 1000)
this->_mMillis -= 1000;
this->_mPacket.TransmitTimestamp_S++;
this->_mError = NO_ERROR;
this->_mState = STATE_WAIT;
break;
case STATE_WAIT:
Serial1.println("D");
this->_mUpdateTimer.changePeriodFromISR(this->_mUpdateTime);
Serial1.println(this->_mUpdateTime);
if(this->_mCallback)
this->_mCallback(this->_mPacket.TransmitTimestamp_S, this->_mMillis, (NTP::Leap)this->_mPacket.LI);
break;
case STATE_TIMEOUT:
Serial1.println("E");
this->_mUpdateTimer.stop();
this->_mError = TIMEOUT;
break;
uint32_t NTP::_power(uint8_t Base, uint8_t Exp)
uint32_t Result = 0x01;
for(uint8_t i = 0x00; i < Exp; i++)
Result *= Base;
return Result;
This will produce the following output:
A
C
D
120000
Now the hard fault (SOS - 1x Blink) occur and the particle resets.
So what can produce this kind of error?
