Hacking on the Spark API with Node.js
I just banged out a web app using Node.js to interface with the Spark API. I was yeah baby this is going to be awexome!
\node spark.js
"getaddrinfo ENOTFOUND"
:cry: I'm getting errors that the address is not valid.
So then going back to simple requests through my browser:
https://api.sprk.io/v1/devices/elroy%20-d%20message=winning
both give me a similar response
not found
The URL you want to access is
You have to do this with a POST request, and the data you want to send is
message=winning
If this still doesn’t make sense, try pasting your spark.js into a gist:
https://gist.github.com/
and share the URL to the gist here. Then someone can help you debug.
Thanks for the fast reply! That totally makes sense to me, but...
I was starting with HTTP GET requests since the documentation states:
HTTP GET requests retrieve data from a device without changing its state.
I guess I should read better… seems like for GET I should use this test URL
https://api.sprk.io/v1/devices/elroy_box/events
However I’m getting the same response.
Yeah, that’s a general guidance rule about REST APIs. The only GET request documented in the API right now is the SSE route (e.g., https://api.sprk.io/v1/devices/elroy_box/events) which you can try and see that the connection stays open, but there’s no core sending any data to that stream. The two routes for controlling a device are POST requests.
Oh come on… you guys don’t have a Spark Core in a closet somewhere spitting out digits of Pi? :wink:
Will there be a more simple GET request that we can just query a snapshot of the pins, or even one specific pin?
Also so far I kind of have POST requests working with the ‘request’ library, but Node’s built in ‘https’ library is complaining a lot! :slight_smile: I’ll keep debugging… this is how I learn.
What kind of response should I get from sending { ‘message’: ‘winning’ } ?
Currently I’m getting
  "ok": false,
  "errors": [
    "No valid pin or custom message found"
My code:
var request = require('request');
request.post(
    'https://api.sprk.io/v1/devices/elroy',
    //{'pin':'D0', 'level':'HIGH'},
    {'message':'winning'},
    function (error, response, body) {
        if (!error && response.statusCode == 200) {
            console.log(body);
        else
            console.log('ERROR: '+error+' '+response+' '+body);
You can see how I tried to set the pin high as well… I get the same response with that one. Probably something I’m not understanding about the request library yet.
I’m trying this as well with the same response.
request.post(
    { 'content-type': 'application/json',
        body: JSON.stringify({'message':'winning'})
            console.log(body);
        else
Please don’t tell me there is no other response currently (like anything that sets {ok:true} because I’ll have to cry… briefly.
Ok, I got it working and saw the {“ok”: true} response… then I cried a bit… now I’m all smiles. I can set pins and see the error message when the pin numbering is out of scope. I’ll try to wrap this up into a nice example for anyone that might want to use Node.js :smiley:
That would be cool. Still waiting on mine, though.
I don't have one either... just passing the time with my addiction to Node.js :smile:
Check out this simple Node.js wrapper I whipped up today for the Spark API
Currently supports simple pin setting high/low and custom messages, with callbacks!
digitalWrite(D0,HIGH);
sendMessage('winning');
Right now the examples are at the bottom of the sparkapi.js file. I'll break them out later in a separate examples folder to keep the wrapper clean.
Hopefully I can add the simple GET request for digitalRead() when Spark documents it. SSE Streaming is cool, but I'm not sure how to handle it well yet.
Cool, I starred it. Hey, we both forked Alain Gilberts code for turntable bots. :slight_smile:
Gonna check this out later, man. Thanks!
That’s where I recognize your name from! I was like… dang I know this guy. I just retired from a year of TT.FM and well over 10,000 lines of code for many different projects there.
Spark Core is going to be a wild ride for sure.
