jrjack
September 8, 2019, 10:53pm
1
I have a Particle Argon, and was trying to interface the GY 521 module with it. As a test i modified the example code, however i am not getting anything on the console. Any thoughts what i am doing wrong?
#include "MPU6050.h"
int ledPin = D7;
// MPU variables:
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
bool ledState = false;
void toggleLed() {
ledState = !ledState;
digitalWrite(ledPin, ledState);
pinMode(ledPin, OUTPUT);
accelgyro.initialize();
// read raw accel/gyro measurements from device
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
/* Serial.print("a/g:\t");
Serial.print(ax); Serial.print("\t");
Serial.print(ay); Serial.print("\t");
Serial.print(az); Serial.print("\t");
Serial.print(gx); Serial.print("\t");
Serial.print(gy); Serial.print("\t");
Serial.println(gz);*/
Particle.publish("LOOP", PRIVATE);
Particle.publish("AX", String(ax), PRIVATE);
ScruffR
September 9, 2019, 5:03am
2
Can’t say about the sensor, but your publishes will most likely violate the rate limit of max. 4/second.
After the first four events your device will be silenced.
jrjack
September 9, 2019, 8:53am
3
Thanks for the reply, i was gonna add a 5 seconds delay. However, i am not able to flash my code. I am using the WEB IDE, and although my Argon is connected and showing its connected to the cloud, the WEB IDE is showing it as offline. Any idea why?
ScruffR
September 9, 2019, 9:13am
4
You can put the device in Safe Mode or flash via USB.
jrjack
September 9, 2019, 9:18am
5
Thanks! Putting into safe Mode did the trick. But not the delay
delay(5000);
console just stops here
From the console it show offline … SO something happened somewhere - my goto test is this - flash it and make sure local output works, console works and led blinks. Not great code but a quick sanity check!
SYSTEM_THREAD(ENABLED);
ApplicationWatchdog wd(30000, System.reset);
SerialLogHandler logHandler(LOG_LEVEL_WARN, // Logging level for non-application messages
{ "app", LOG_LEVEL_ALL } // Logging level for application messages
int led = D7;
const int delayTime = 10000; //
const char str_deviceOS[] = "DeviceOS";
const int sizeOfTempText = 128;
char tempText[sizeOfTempText];
Serial.begin(115200);
waitFor(Serial.isConnected, 30000);
Log.info("Started.....waiting for Cloud");
if (waitFor(Particle.connected, 30000)) {
Log.info("Started at %s", Time.timeStr().c_str());
else {
Log.info("Started.....no Cloud");
snprintf(tempText, sizeOfTempText, "%s", System.version().c_str());
Log.info("%s %s", str_deviceOS, tempText);
Particle.publish(str_deviceOS, tempText, PRIVATE);
pinMode(led, OUTPUT);
pinMode(PWR, INPUT);
pinMode(CHG, INPUT);
wd.checkin(); // resets the AWDT count
Serial.println(Time.timeStr()); //
digitalWrite(led, !digitalRead(led));
checkBattV();
checkBattC();
checkVUSB();
delay(delayTime);
float checkBattV()
float battVoltage = analogRead(BATT) * 0.0011224;
Particle.publish("battery_voltage", String::format("%.2f",battVoltage), PUBLIC);
Log.info("Batt level:%.2fV",battVoltage);
return battVoltage;
bool checkBattC()
bool charging = !digitalRead(CHG);
Particle.publish("battery_charging", charging ? "yes" : "no", PUBLIC);
Log.info("Batt %s charging", charging ? "is" : "not");
return charging;
bool checkVUSB()
bool powerState = digitalRead(PWR);
Log.warn(powerState ? "Power ON" : "Power FAIL");
Particle.publish("power_state", powerState ? "on" : "off", PUBLIC);
return powerState;
ok so you now know your device is ok, the cloud is ok and the console is ok.
So comment out sections of your code until it works - I would start with this and add back in code until it fails …
Make the last line of your setup() a publish so you know the loop() will start next
// your start-up stuff
Particle.publish("DEBUG", "setup() done", PRIVATE);
//accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
Particle.publish("DEBUG", loop()", PRIVATE);
//Particle.publish("AX", String(ax), PRIVATE);
delay(5000);
You should now have 5s message - then add back the serial.prints and check local serial output (making sure you have the vars ax/y/z and gx/y/z defined somewhere.
What happens?
Hey @jrjack , looking at the GY-521, it communicates via I2C, for that you need to initiate it first. I would take the original code you posted, and in the setup() add the line Wire.begin().
And secondly, as @ScruffR pointed out, add some delay to your publishing messages.
jrjack
September 9, 2019, 10:12am
10
thank you so much @muneebr1 Seems to be working now
