Grove NFC- I2C scanner found device, reading not working
Hello, so i have recently finished cutting my grove NFC to I2C. My I2C scanner found my device, my code below flashed with no problems. when i open serial monitor to see if the device is reading this is what i get. Please if someone can help me i am running on a deadline :-1: Thanks Beforehand!
18%20PM
current code
 #define SYSTEM_THREAD(ENABLED)
#include <Adafruit_PN532/Adafruit_PN532.h>
#include <Wire.h>
#include <SPI.h>
#define PN532_MODE (PN532_I2C_MODE)
#define IRQ_PIN  (D0) // This is how the PN532 Shield gets ready status in I2C mode
#define RST_PIN  (D1) // Necessary for I2C mode
Adafruit_PN532 nfc(RST_PIN,IRQ_PIN);
void setup(void) {
  Serial.begin(9600); // Make sure your serial terminal is closed before power the Core.
  Serial.println("Hello!");
  nfc.begin();
  uint32_t versiondata;
  do {
    versiondata = nfc.getFirmwareVersion();
    if (!versiondata) {
      Serial.print("Didn't find PN53x board\n");
      delay(1000);
      Particle.process();
    Particle.process();
  }while(!versiondata);
  // Got ok data, print it out!
  Serial.print("Found chip PN5\n"); Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. \n"); Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
  // configure board to read RFID tags
  nfc.SAMConfig();
void loop(void) {
  Particle.process();
  Serial.println("Waiting for an ISO14443A Card ...\n");
  delay(1000);
  uint8_t success;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
  uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
  // 'uid' will be populated with the UID, and uidLength will indicate
  // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
  if (success) {
    // Display some basic information about the card
    Serial.println("Found an ISO14443A card");
    Serial.print("  UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
    Serial.print("  UID Value: ");
    nfc.PrintHex(uid, uidLength);
    if (uidLength == 4)
      // We probably have a Mifare Classic card ...
      uint32_t cardid = uid[0];
      cardid <<= 8;
      cardid |= uid[1];
      cardid <<= 8;
      cardid |= uid[2];
      cardid <<= 8;
      cardid |= uid[3];
      Serial.print("Seems to be a Mifare Classic card #");
      Serial.println(cardid);
    Serial.println("");
  }  else {
    Serial.println("nfc.readPassiveTarget Failed\n");
Current tags; https://www.amazon.com/gp/product/B0716SXJ3S/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
@talalgedeon, you may want to revisit the example you based your code on, especially the location of the delay(1000). As it stands, your code only test the presence of a card every second whereas in the example, the sampling is done continuously and the one second delay only comes AFTER a card is successfully read. I suspect you did this because the message “nfc.readPassiveTarget Failed” prints rapidly on the console since nfc.readPassiveTargetID() will return immediately if no card is found. You could comment out that print line to avoid that.
Also, if a card is read and uidLength is not 4 nothing happens. You may want to add an else statement to indicate the card read has a uidLength of xx for example.
