GPS module for Photon?
The Adafruit GPS modules based on the PA6H chips are compatible with the AssetTracker v1, as well. You can even use the same libraries.
If you put a MOSFET on pin D6 to control the power to the breakout board and added a LIS3DH accelerometer, it would functionally identical.
