Resurrecting the thread, sorry. Seems to make more sense to keep it here.
Both the proposed code sets are failing for me. I’m building on 0.8.0-rc11 using the Web IDE. (EDIT: downgraded and tested on 0.7.0 with same result).
When using @AaronD 's code (shared) and below, it works fine when the WiFi network is present. I see 3 blue flashes and it connects. However, when the WiFi is not present (also when present but not connected to the internet), it goes through a cycle with red flashes/green but never enters blue flashing listening mode (the flashing is fast and crazy in a way I can’t follow whether it is an SOS or simply no internet/cloud connection).
I feel telling, there is neither the expected 6 LED flashes nor 3.
On the other hand, @nrobinson2000 's post #7 code when WiFi is present never connects and remains in green breathing state. I can’t figure out what the problem is.
I’ve re-read the docs on all the WiFi instructions and can’t seem to find anything wrong with either code…yet neither works.
#include "Particle.h"
#include "softap_http.h"
SYSTEM_MODE(SEMI_AUTOMATIC);
SYSTEM_THREAD(ENABLED);
// INITIALIZE VARIABLES =================================
int LED = D7; // LED = onboard LED pin (D7).
bool newWiFi = false; // Flag to indicate looking for new WiFi credentials.
STARTUP(WiFi.setListenTimeout(120)); // Set max time to listen for new WiFi credentials.
// SETUP ================================================
pinMode (LED, OUTPUT); // Set LED pin to OUTPUT mode.
WiFi.on(); // Do manual WiFi initialization
WiFi.connect();
if(waitFor(WiFi.ready, 15000)) { // Wait 15 seconds to find WiFi network
for (int i = 0; i < 3; i++) { // 3 Flashes = we have WiFi.
digitalWrite(LED, HIGH); // Send signal then...
delay(100);
digitalWrite(LED, LOW);
delay(100);
Particle.connect(); // Connect to Particle Cloud.
else {
for (int i = 0; i < 6; i++) { // 6 Flashes = no WiFi found after 15 sec.
delay(100);
delay(100);
WiFi.disconnect(); // Disconnect WiFi.
newWiFi = true; // Set flag to say we are listening for new WiFi credentials.
WiFi.listen(); // Listen for new WiFi credentials.
// MAIN PROGRAM LOOP =====================================
if ((newWiFi) && (!WiFi.listening())) {
System.reset(); // If newWiFi and ListenTimeout already expired, reset.
// Do Stuff() // Do rest of loop() code which will run while listening for new WiFi credentials.
