I have a problem, when i go to the new wifi
How can I auto turn to the listen mode after 5 minutes if not connect to wifi
By looking in the docs you might have found these
https://docs.particle.io/reference/firmware/photon/#listen-
https://docs.particle.io/reference/firmware/photon/#ready-
https://docs.particle.io/reference/firmware/photon/#system-thread
Have I turn to SEMI_AUTO mode
You can use SEMI_AUTOMATIC, but SYSTEM_THREAD(ENABLED) should be enough to ensure your code is running even when disconnected and hence being able to check connection status and enter Listening Mode.
But I’m usually going SEMI too - just for safe measure.
SYSTEM_THREAD(ENABLED);
uint8_t retry_count = 0;
WiFi.on();
WiFi.connect();
if(!WiFi.ready()){
retry_count += 1;
if ((retry_count >= 100)&&(WiFi.ready() == false))
WiFi.listen();
if (WiFi.ready() == true) Particle.connect();
Here is my code, but it’s still not work, can you give me a suggest
Yes, it’s work, thanks you
