Getting the RFID-RC522 to work! [SOLVED]
Not bumping this thread due to a problem on my end, just wanted to say that thanks to this thread and @peekay123’s library, I was able to get this ebay kit up and running on a Photon in about 4 minutes!
Any future Googlers looking for a quick start, here’s a summary of this thread:
Wiring:
-Function-         Photon Pin        MRFC522 Pin
 Reset             ANY (D2)	     RST
 SPI SS            ANY (A2)	     SDA
 SPI MOSI          A5		     MOSI
 SPI MISO          A4		     MISO
 SPI SCK           A3		     SCK
Code:
This will publish an event to the Particle cloud with the ID of whatever device you scan - kind of a RFID hello world, as it doesn’t really do much beyond let you catalog the cards and fobs you have, and ensure you’ve wired it up right. Make sure you add the MFRC522 library through the IDE, I’m not sure how it works if you just paste this with the include statement.
#include <MFRC522.h>
#define SS_PIN      A2
#define RST_PIN     A1
MFRC522 mfrc522(SS_PIN, RST_PIN);	// Create MFRC522 instance.
    SPI.begin();
    SPI.setClockDivider(SPI_CLOCK_DIV8);
    mfrc522.PCD_Init();
    // Look for new cards, if nothing found, quit
    if ( ! mfrc522.PICC_IsNewCardPresent()) {
    	return;
    // Select one of the cards, if nothing found, quit
    if ( ! mfrc522.PICC_ReadCardSerial()) {
    	return;
    String cardID = "";
    for (byte i = 0; i < mfrc522.uid.size; i++) {
        cardID += String(mfrc522.uid.uidByte[i] < 0x10 ? "0" : "");
        cardID += String(mfrc522.uid.uidByte[i], HEX);
    Particle.publish("rfid_scan", cardID, 60, PRIVATE);
    mfrc522.PICC_HaltA();
Now for some RFID fun! Thanks everyone!
