I work with computers for a living, but today the Photon Weather Shield has me a little stumped. I’ve spent the better part of a day with it, and while I’ve made a fair amount of what I consider progress, I’m nowhere near having this device operational.
Here’s what I have tried so far:
I’ve read the Photon Weather Shield tutorial at least a dozen times.
I updated my Core with the deep_update and cc3000 binaries
The core logs in and “breathes” normally.
I created the stream, and put my keys inside the Phant module.
If I use the DEV IDE, it says can’t find the OneWire.h library during a verify. I found one on GITHUB, but it has a different name there. Is this still the same library? Is it safe to rename a library?
If I use the on-line BUILD IDE, I have located and included all the libraries required for the shield, but I can’t find the app “driver” source code. If I copy/paste the SPARKFUN_PHANT.INO source code into the web BUILD IDE, I get compiler warnings and errors. Am I using the wrong .INO/CPP to call everything?
Any hints, tips, techniques or links to help me get this running are most appreciated!
-Joe
