GET reads all return same variable value
I’m trying to read a variable value using the Cloud API, but everything I read seems to come back as the same raw value of " P". Any idea as to why?
https://api.spark.io/v1/devices//counter1?access_token=(will change token at a later date, try now for troubleshooting)
Code:
int counter1 = 0;
int counter2 = 53;
    pinMode(D2, OUTPUT);
    digitalWrite(D2, HIGH);
    delay(250);
    digitalWrite(D2, LOW);
    delay(1000);
   counter1++;
   counter2++;
Response:
cmd: "VarReturn"
TEMPORARY_allTypes: {
string: " P"
uint32: 536891392
number: 536891392
double: null
float: 1.0868491504456741e-19
raw: " P"
result: " P"
coreInfo: {
last_app: ""
last_heard: "2014-01-05T19:39:03.987Z"
connected: true
deviceID: "53ff67065067544825071287"
If you check that URL out in a browser, the raw value actually seems to be " \u0000P\u0000"… the app I’m using to format GET/POST requests formats the unicode I guess.
Why does the GET not return the proper value of counter1 or counter2?
You need to add these two lines to your setup()
Spark.variable("counter1",&counter1,INT);
Spark.variable("counter2",&counter2,INT);
Should work after that :wink:
Also if you ever see that string: " P" you know you have an error in how you are trying to read the variable. It should probably give you an error and say that the requested varKey is undefined
Ugh… the learning, it hurts so good! This has probably been asked a million times, but is there a section of documentation that contains this particular feature? I can’t shake the feeling that I’m missing something huge.
Thanks a ton for the pointer :smile:
No problem! Here’s a link to the Core Firmware Reference:
http://docs.spark.io/#/firmware/cloud-spark-variable
Holy… yep, missed those examples. You guys rock, thanks again!
So… uh… do float values work?
Code:
float h;    // humidity
Setup:
Spark.variable("h",&h,FLOAT);
Error:
error: 'FLOAT' was not declared in this scope
Nope, but DOUBLE will compile… however won’t give you a valid value yet from the cloud. A fix is in the works!
For now you can do this, and send you DOUBLE or FLOAT as a string:
double temperature = 1.0;
char myStr[10];
  Spark.variable("read", &myStr, STRING);
  temperature += 0.5;
  sprintf(myStr,"%.2f",temperature);
  delay(500);
Absolutely beautiful. Humidor Tweetbox 1.0-beta complete! Many thanks :smiley:
