I want get current hour from particle and use that value inside an if for sample:
IF hour < 16 {
I don’t know how put the hour inside a variable and after use it inside the if.
Roberto
IF hour < 16 {
Roberto
The relevant docs is here: https://docs.particle.io/reference/firmware/electron/#time
You should be looking for something like:
if (Time.hour() < 16) {
int currentHour = Time.hour()
Thank you, works fine.
