Dilbert
September 28, 2014, 12:28am
1
I try to get the token with HTML file. But don’t know the format. I tested with curl according to doc as follow and it works.
curl https://api.spark.io/v1/access_tokens -u joe@example.com:SuperSecret
But when testing with $.getJSON(requestURL, function(data){}); in HTML, it does not work.
What is the format should be ?
var requestURL = "https://api.spark.io/v1/access_tokens -u joe@example.com:SuperSecret"
Heya @Dilbert !
jQuery requires a slightly different way to pass in a HTTP Basic Auth token:
$.ajax({
url: 'https://api.spark.io/v1/access_tokens',
beforeSend: function (xhr) {
xhr.setRequestHeader("Authorization", "Basic " + btoa('username:password'));
success: function(data) {
// here you go! example:
console.log(data);
alert('first token: '+data[0].token);
You might want to take a look at sparkjs though, as it abstracts all that for you!
With sparkjs:
spark.login({username: 'foo@bar.com', password: 'pw'}, function(err, body) {
console.log(body.access_token);
Enjoy!
Dilbert
September 28, 2014, 3:48am
3
Thanks, it works. Is the sparkjs recently available. I did not notice this before.
Also, is this normal my core would have 6 Access Token assigned. One is User and other 5 are Spark related.
Very fresh indeed - started 9 day ago
First at all, they are assigned to your account, not to a single core.
The number of access tokens depend on your different use cases - you'll see only one for the spark-ide but most likely many for spark-cli, spark, Spark and so on. Any time you login again via one of the many ways, a new token is created. To avoid -> reuse your tokens To cleanup -> use the API
Dilbert
November 1, 2015, 12:34am
5
Getting the access token with user email+password and it works.
But when I try different command, get list of devices in account. Then it does not work. Any ideas ?
url: “https://api.particle.io/v1/devices ”
