Get FCC and IC IDs via API from Device ID?
Hi everyone,
I'm trying to programmatically determine a device's agency information in order to show it on the display. Is it possible to look up the FCC ID and IC ID from a Device ID or serial number using an API? Alternatively, is there a way to look up an ID for the model? I know that models like BSOM and MSOM have product IDs, but since M404 and M635 wouldn't have the same FCC IDs, I'd need to differentiate between the two.
Not sure if the cloud API gets you the FCC/IC IDs, but I was able to find those here. Looks like a third party site though so it may not be exhaustive or accurate. If you look at the label location PDFs they show the IDs.
There is no API to find the FCC ID for a given platform ID or SKU.
