Generation of firmware (GCC), without flash option
HI,
I currently try to generate the “modules” firmware without ‘program-dfu’ option (I have no access to USB from the compilation server), then:
  • I change directory to modules\
  • I launch the make => make PLATFORM=P1 clean all
The compilation succeeded but I don’t find any generated .bin file that could match with the firmware to load (locally)
Could I use the make in this purpose ?
If yes, where is the corresponding generated .bin file that I could load (via “particle flash --usb <Firmware.bin>”) ?
Thank you
@slorre - I am assuming you are using the local toolchain to compile firmware.
There is a base directory where the source tree lives, lets call this ${SRC}.
The instructions for compiling are to cd firmware/modules.
You indicated make PLATFORM=P1 clean all.
Have a look around in ${SRC}/firmware/build/target/...
On a unix compatible platform, you can use the find command. Notice the recently compile firmware for Aug 8 below. There is a lot of other stuff in there.
cd ${SRC}
$ find . -name \*.bin -exec ls -l {} \;
-rw-r--r--  1 cermak  staff  22820 Jul  7 13:50 ./firmware/bootloader/tools/locker-firmware.bin
-rw-r--r--  1 cermak  staff  18756 Jul  7 13:50 ./firmware/bootloader/tools/unlocker-firmware.bin
-rwxr-xr-x  1 cermak  staff  15712 Aug  2 20:49 ./firmware/build/target/bootloader/platform-6-lto/bootloader.bin
-rwxr-xr-x  1 cermak  staff  255832 Jul 28 12:41 ./firmware/build/target/system-part1/platform-6-m/system-part1.bin
-rwxr-xr-x  1 cermak  staff  255832 Aug  8 07:52 ./firmware/build/target/system-part1/platform-8-m/system-part1.bin
-rwxr-xr-x  1 cermak  staff  214652 Jul 28 12:41 ./firmware/build/target/system-part2/platform-6-m/system-part2.bin
-rwxr-xr-x  1 cermak  staff  214888 Aug  8 07:53 ./firmware/build/target/system-part2/platform-8-m/system-part2.bin
-rwxr-xr-x  1 cermak  staff  7424 Jul  7 13:59 ./firmware/build/target/user-part/platform-6-m/user-part.bin
-rwxr-xr-x  1 cermak  staff  7424 Aug  8 07:53 ./firmware/build/target/user-part/platform-8-m/user-part.bin
-rw-r--r--  1 cermak  staff  8 Jul  7 13:50 ./firmware/hal/src/electron/dct_header.bin
-rw-r--r--  1 cermak  staff  32768 Jul  7 13:50 ./firmware/hal/src/photon/dct_prep.bin
-rwxr-xr-x  1 cermak  staff  4660 Jul 25 21:58 ./firmware/modules/classtest/target/classtest.bin
-rwxr-xr-x  1 cermak  staff  4676 Jul 22 07:49 ./firmware/modules/fwtests/target/fwtests.bin
-rwxr-xr-x  1 cermak  staff  89476 Jul 28 12:41 ./firmware/modules/wolfiot/target/wolfiot.bin
-rwxr-xr-x  1 cermak  staff  23908 Jul 15 17:18 ./firmware/modules/wolfmqtt/target/wolfmqtt.bin
-rwxr-xr-x  1 cermak  staff  96968 Jul 19 08:16 ./firmware/modules/wolfrc/target/wolfrc.bin
-rw-r--r--  1 cermak  staff  16384 Jul  7 13:50 ./firmware/user/tests/unit/corrupted_eeprom_page1.bin
-rw-r--r--  1 cermak  staff  65536 Jul  7 13:50 ./firmware/user/tests/unit/corrupted_eeprom_page2.bin
-rw-r--r--  1 cermak  staff  16384 Jul  7 13:50 ./firmware/user/tests/unit/eeprom_page1.bin
If you are on Windows, then I am at a loss to find things on the command line. You can use windows explorer to find the *.bin files and discover the path to them.
Yes I compile with local toolchain.
Concerning the generated *.bin files Ifound 3 that seem to match (2 for the system, 1 for the application):
-rwxrwxr-x 1 257120 Aug 8 18:28 ./build/target/system-part1/platform-8-m/system-part1.bin
-rwxrwxr-x 1 214448 Aug 8 18:30 ./build/target/system-part2/platform-8-m/system-part2.bin
-rwxrwxr-x 1 7096 Aug 8 18:31 ./build/target/user-part/platform-8-m/user-part.bin
But I expected only one (or two max).
I suppose that we can’t load them individually, one after another, with “particle flash --usb Firmware-x.bin”
Should we concatenate them, or specify adresses for each load, Perhaps a process to follow ?
Thank you
The firmware I showed you is the core firmware that the device is running. I now think you are trying to find your project firmware that you would run on the device?
You would place your code into a project directory, this is also called the APPDIR.
See if these instructions help.
${SRC}/${APPDIR}
The project firmware would be in the respective target directory.
Three is the correct number of parts for a P1 build. Two system parts and one user part.
However if you clone out the source from a release tag and make no other modifications or option changes to the system parts, you can use the standard pre-built system firmware so you don’t need to flash those. Just flash your user-part.bin, which is basically the same file as you’d get from the cloud compilers.
As your iterating your user firmware code, normally you just build from firmware/main which only builds the user-part and saves a great deal of build time.
If you’re going to use gdb, that’s an entirely different thing as you need a monolithic binary which only has one part that contains the system and user parts.
