Function attachInterrupt() returns value
The function attachInterrupt in spark_wiring_interrupts.cpp of 0.4.9 FW returns value of type bool. However, in the reference online document https://docs.particle.io/reference/firmware/photon/#attachinterrupt-, it says The function does not return anything.
Request Particle to update the online reference document if this observation is correct.
Thanks.
Thanks for the hint, but if you find things that are obviously out of date you can even update the docs yourself
Update:
I’ve changed the statement and it’s already online. , should be online in a few minutes.
@ScruffR, thank you for the update and information. Good day.
