Sorry if this has been documented or discussed elsewhere, but I can’t for the life of me find any documentation for the following functions in the FuelGauge library:
Ok, I found the SparkFunMAX17043 library reference, which it appears the Particle FuelGauge library was based on.
Unfortunately, the FuelGauge library doesn’t seem to be properly initializing when I call quickStart(), and it never registers above 83%, even when fully charged (using the 2000mAH lipo from the asset tracker kit). Do I need to manually set the lipo capacity using the FuelGauge library, or should quickStart() automatically calibrate everything properly?
you’re talking about the Electron, I assume. And yeah, mine never shows above 83% or so (I don’t remember the exact percentage offhand). Further, are you able to properly init a global FuelGauge? It fails when I attempt to do so- I can only define it within a function.
The SparkFun gauge, used on the Photon, doesn’t have either of the above problems.
Yes, this is regarding the Electron. Interesting that you’re seeing the same SOC reporting issue…
FuelGauge seems to be initializing fine for me, here is a snippet from my code–
#include "TinyGPS.h"
String LastLocation;
FuelGauge fuel;
TinyGPS gps;
void setup(){
Particle.function("pubstatus", PubStatus);
fuel.quickStart();
void loop(){
int PubStatus(String checkstatus) {
String str = LastLocation + " - Battery: " + String(long(fuel.getSoC())) + "%";
Particle.publish(CurrentState, str);
By chance, have you tried seeing if the SparkFun library is usable on the Electron? (not sure if it could be tweaked to work without clashing with the built-in library?)
