Flashing Photon bootloader using debugger
Hi -
I have read through some available articles on using the debugger to flash boorloader and other system files but have been unable to get it working.
Here is what I have done so far:
  • Installed BREW first
  • Then installed OpenOCD via Workbench - all seems to be in order.
  • Downloaded necessary files from Github.
I then run the following, tried via both Workbench and terminal, same result.
bin/openocd -f interface/cmsis-dap.cfg -f target/nrf52-particle.cfg \
-c "reset halt" \
-c "flash protect 0 0 0 off" \
-c "program /Users/friedlbasson/Downloads/photon-bootloader@1.5.1+lto.bin
    verify 0x08000000" \
-c "flash protect 0 0 0 on" \
-c "exit"
This is where the trouble start. It gets to this section here, but then nothing..
Info : SWD DPIDR 0x2ba01477
Info : stm32f2x.cpu: hardware has 6 breakpoints, 4 watchpoints
Would appreciate some help :slight_smile:
Regards.
Friedl.
