Hi All,
I am using the flashee-eeprom library and on system reset the vales read are incorrect (-1). This issue is leading to a lot of incorrect values in the database and app crashes due to it. Does this happen due to flash wearing out?
The flash device used is:
FlashDevice* Spi_Flash; // declared global
Spi_Flash= Devices::createAddressErase(); // defined in a init function
Help needed urgently. Just due to this we have to use an external eeprom which is adding cost to the product.
@NS_Blue, are you using a P1 module?
Apologies for not giving the entire details.
Yes I am using P1. with 0.6.3 firmware.
The erased value for the flash is 0xff, so I’d kind of expect values of -1 if they’re a signed value.
Yes. Thats exactly whats happening. But I want to figure out why am I getting erased values? One data point is that I had used the flash as createWearLevelErase before making it createAddressErase. And I did the implementation testing on this Photon. Is that why its got corrupt?
