Finding a device using scanWithFIlter
Simple question: I would like to use scanWithFIlter() to find a specific device. I would like to use the address as a filter. so, how to I create the filter? I am currently using this code:
String address = "C9D8320B20C9";
filter.address(address);
Vector BleScanResult> results = BLE.scanWithFilter(filter);
but this is returning no results. Any help would be appreciated, thanks
Can you try this
BleScanResult scanResult;
BleAddress addr("C9:D8:32:0B:20:C9", BleAddressType::RANDOM_STATIC);
if (BLE.scanWithFilter(BleScanFilter().address(addr), &scanResult, 1))
  Serial.printlnf("found device %s", (const char*)scanResult.advertisingData().deviceName());
When you scan for a device without filter you can check the BleAddressType of the found devices and use that info to then define the filter accordingly.
Awesome thank you this works!!
