I have an implementation of the File system on OS 4.2.0. During some boots, the struct returned from readdir() gives a file name (d_name) with strange symbols, so the unlink will fail. It works fine on some boots. Has anyone seen something like this before? From what I can tell, I never created a file with this name.
int RemoveTree(const char* path, uint32_t& iter_guard)
DIR* dir = opendir(path);
int returnVal = -1;
if (dir) {
struct dirent *dirent;
returnVal = 0;
while(!returnVal && (dirent=readdir(dir))) {
char *tmpbuf;
size_t length;
if (strcmp(dirent->d_name, ".") == 0 || strcmp(dirent->d_name, "..") == 0)
continue;
length = strlen(path) + strlen(dirent->d_name) + 2;
tmpbuf = (char*)malloc(length);
if (tmpbuf) {
if (path[strlen(path)-1] == '/') snprintf(tmpbuf, length, "%s%s", path, dirent->d_name);
else snprintf(tmpbuf, length, "%s/%s", path, dirent->d_name);
switch(dirent->d_type) {
case DT_DIR:
if (!returnVal){
returnVal = RemoveTree(tmpbuf, iter_guard);
if (returnVal) Serial.println("RemoveTree() - Recursive call failure");
break;
default:
if (!returnVal)
returnVal = unlink(tmpbuf);
if(returnVal)
Serial.println("RemoveTree() - unlink failure");
Serial.println(tmpbuf);
Serial.println(dirent->d_name);
break;
closedir(dir);
if (!returnVal)
returnVal = rmdir(path);
if (returnVal)
Serial.println("RemoveTree() - rmdir failure");
Serial.println(path);
return returnVal;
Here's an image of when the unlink fails.
