I am new to using my Photons and have been running to to errors anytime I try to use code written using FastLED from different sites. I for example noticed that some colors used on the LEDs are not exactly correct and found the code below when I did a google search on how to adjust the colors. I copied the code over to me editor (shown below) and get the following error messages when I compile it. Odds are it is something simple I am missing. Any help would be great
Errors -----
colortest1.ino:9:1: 'CRGB' does not name a type
colortest1.ino:56:17: 'leds' was not declared in this scope
colortest1.ino:56:55: 'fill_rainbow' was not declared in this scope
colortest1.ino:61:5: 'FastLED' was not declared in this scope
colortest1.ino:44:23: 'Tungsten100W' was not declared in this scope
colortest1.ino:64:5: 'FastLED' was not declared in this scope
colortest1.ino:45:23: 'OvercastSky' was not declared in this scope
colortest1.ino:71:41: 'CRGB' was not declared in this scope
colortest1.ino:74:3: 'FastLED' was not declared in this scope
colortest1.ino:82:3: 'FastLED' was not declared in this scope
colortest1.ino:7:21: 'WS2811' was not declared in this scope
colortest1.ino:8:21: 'GRB' was not declared in this scope
colortest1.ino:82:50: 'leds' was not declared in this scope
colortest1.ino:82:81: 'TypicalSMD5050' was not declared in this scope
Code —
#include <FastLED.h>
#define LED_PIN 6
// Information about the LED strip itself
#define NUM_LEDS 50
#define CHIPSET WS2811
#define COLOR_ORDER GRB
CRGB leds[NUM_LEDS];
#define BRIGHTNESS 128
// FastLED v2.1 provides two color-management controls:
// (1) color correction settings for each LED strip, and
// (2) master control of the overall output 'color temperature'
// THIS EXAMPLE demonstrates the second, "color temperature" control.
// It shows a simple rainbow animation first with one temperature profile,
// and a few seconds later, with a different temperature profile.
// The first pixel of the strip will show the color temperature.
// HELPFUL HINTS for "seeing" the effect in this demo:
// * Don't look directly at the LED pixels. Shine the LEDs aganst
// a white wall, table, or piece of paper, and look at the reflected light.
// * If you watch it for a bit, and then walk away, and then come back
// to it, you'll probably be able to "see" whether it's currently using
// the 'redder' or the 'bluer' temperature profile, even not counting
// the lowest 'indicator' pixel.
// FastLED provides these pre-conigured incandescent color profiles:
// Candle, Tungsten40W, Tungsten100W, Halogen, CarbonArc,
// HighNoonSun, DirectSunlight, OvercastSky, ClearBlueSky,
// FastLED provides these pre-configured gaseous-light color profiles:
// WarmFluorescent, StandardFluorescent, CoolWhiteFluorescent,
// FullSpectrumFluorescent, GrowLightFluorescent, BlackLightFluorescent,
// MercuryVapor, SodiumVapor, MetalHalide, HighPressureSodium,
// FastLED also provides an "Uncorrected temperature" profile
// UncorrectedTemperature;
#define TEMPERATURE_1 Tungsten100W
#define TEMPERATURE_2 OvercastSky
// How many seconds to show each temperature before switching
#define DISPLAYTIME 20
// How many seconds to show black between switches
#define BLACKTIME 3
// draw a generic, no-name rainbow
static uint8_t starthue = 0;
fill_rainbow( leds + 5, NUM_LEDS - 5, --starthue, 20);
// Choose which 'color temperature' profile to enable.
uint8_t secs = (millis() / 1000) % (DISPLAYTIME * 2);
if( secs < DISPLAYTIME) {
FastLED.setTemperature( TEMPERATURE_1 ); // first temperature
leds[0] = TEMPERATURE_1; // show indicator pixel
} else {
FastLED.setTemperature( TEMPERATURE_2 ); // second temperature
leds[0] = TEMPERATURE_2; // show indicator pixel
// Black out the LEDs for a few secnds between color changes
// to let the eyes and brains adjust
if( (secs % DISPLAYTIME) < BLACKTIME) {
memset8( leds, 0, NUM_LEDS * sizeof(CRGB));
FastLED.show();
FastLED.delay(8);
delay( 3000 ); // power-up safety delay
// It's important to set the color correction for your LED strip here,
// so that colors can be more accurately rendered through the 'temperature' profiles
FastLED.addLeds<CHIPSET, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalSMD5050 );
FastLED.setBrightness( BRIGHTNESS );
