Per docs Particle.connect
After you call Particle.connect(), your loop will not be called again until the device finishes connecting to the Cloud. Typically, you can expect a delay of approximately one second.
Can someone comment what happens if there is no valid SSID in the vicinity - does it block for approx 30 seconds - see comment re wifi.connect here starting-spark-core-without-wifi-solved?
Many thanks
John
