I was looking for spark/flash/status events so my app could track the status of flashing and update some UI before allowing the system to be controlled again.
However, I was coding fast and loose and found myself comparing a string with the == operator and scratching my head as to why it wasn't working. It took me a few minutes to see that started and success were actually started and success (with trailing spaces). Comparing with a .contains() method fixed my issue of course, but the API documentation does seem to imply that there are no trailing spaces for the 3 data values. I realize that fixing this could break some integrations (like if they compared a string the way I was as trying to do) so maybe just a note in the docs could be useful otherwise.
This was on a Photon 2, 5.8.0+
