Im designing a product based on the P0, and i just want to put the connector for the external antenna, so i guess i dont need the SKY13350 to switch between the on board and external antenna.
In the schematic for the Photon (https://docs.particle.io/datasheets/photon-datasheet/#schematic-rf) there are a couple of capacitors ( C14 and C17 in the image), and i was wondering if i have to put them, or whats the circuit to connect directly the antenna connector to the ANT pin on the P0.
If you plan to use a connector for the antenna, you can directly connect it to the ANT pin on the P0, making sure that the trace is of 50 ohm impedance. There is no need for any passive components in between.
On a side note, remember that these connectors/plugs are not meant to be plugged and unplugged into more than a few times. I’d recommend when you are designing the final product, use some form of an epoxy putty to seal the antenna connector in place after plugging it in.
