Exchanging strings between tot photon using WIFI (no cloud)
Hello everybody,
I would like to exchange strings between two photons using the WIFI-network that the photons are connected to. For more reliability I would like to use only the WIFI-network, not the internet. Is there a simple example code available that can show you how to do this?
Thanks in advance,
Bart
Had a look here?
https://docs.particle.io/reference/firmware/photon/#tcpclient
Thanks, I’ll have a look at it!
