Hi
I am trying to build an integration between Particle cloud and MongoDB. I have successfully done the post request but when it comes to GET request it keep on giving me 404 error when I test it. Webhook configuration shown just below.
I have used CRUL to perform GET request and it worked fine but the webhook does not work.
I have solved the issue by performing POST method instead of GET method to retrieve the document. They have designed it in that way.
