I’m getting an error while trying to comple the following code in the web IDE
indent preformatted text by 4 spaces
#ifndef UBERDAY
#define UBERDAY
#include <string.h>
class Day{
public:
Day();
String dayOfTheWeekString();
int hour();
int minute();
private:
String doftw;
int h;
int m;
compiler error is as follows:
In file included from Day.cpp:1:0:
Day.h:8:9: error: 'String' does not name a type
Day.h:12:9: error: 'String' does not name a type
String doftw;
Day.cpp:8:1: error: 'String' does not name a type
String Day::dayOfTheWeekString(){
make: *** [Day.o] Error 1
Syntax appears to be correct, is this an IDE issue? Thanks in advance!
@bko is it advised to programming OOP in Spark? I have worked with Arduino and while it’s completely ok to write classes, I was told not to since it can easily overrun the memory.
OO and Classes are great on Spark! But you are writing C++ and not using the wiring/Arduino pre-processor. That means that you have follow all the C/C++ rules for classes, function prototypes etc.
As @Dave says, the memory here for both code and data is better, so it will be fine. Just remember you are on a resource limited platform and if you are creating and destroying objects quickly (like the Arduino String substring method does for instance) then you can run out of memory since no garbage collector is perfect. Static memory allocation works a lot better on resource limited platforms since you the programmer have full control and full responsibility.
@bko that’s good to know. However, is there a performance difference between writing as .ino (using arduino pre-processor) and .cpp and including application.h (using C++ pre-processor), provided I’m not writing OO and not doing any malloc operations?
No, these are compiled by the same compiler in the same way. The Arduino-style preprocessor just makes it easier to ignore some programming details that you have to pay attention to when writing C/C++.
