I’ve been working with my Particle Photon but for some reason today I’ve been unable to run any particle command.
And after trying to flash my Particle Photon, I saw this output from CLI in Windows 10:
! Error in particle-cli:
! Cannot find module 'core-js/modules/es.array.index-of'
! See C:\Users\general_user\AppData\Local\particle\error.log for more info.
Look for the error.log file and this was the output:
2019/08/29 14:56:19 Time since last update 6h9m34.1629292s, update in block
2019/08/29 14:56:24 Time since last update 6h9m39.2707021s, update in background
2019/08/29 14:56:24 Time since last update 6h9m39.2956778s, update in block
2019/08/29 14:56:24 Time since last update 6h9m39.2996752s, update in background
2019/08/29 14:56:25 Manifest version 1.0.1-e04264e, Installed version 1.0.1-e04264e
2019/08/29 14:56:25 Updating CLI...
2019/08/29 15:10:37 Time since last update 14m12.8793967s, update in block
2019/08/29 20:10:38 module.js:550
throw err;
Error: Cannot find module 'core-js/modules/es.array.index-of'
at Function.Module._resolveFilename (module.js:548:15)
at Function.Module._load (module.js:475:25)
at Module.require (module.js:597:17)
at require (internal/module.js:11:18)
at Object.<anonymous> (C:\Users\AIOTIK-005\AppData\Local\particle\node_modules\particle-cli\dist\app\cli.js:3:1)
at Module._compile (module.js:653:30)
at Object.Module._extensions..js (module.js:664:10)
at Module.load (module.js:566:32)
at tryModuleLoad (module.js:506:12)
at Function.Module._load (module.js:498:3)
2019/08/29 15:10:38 Time since last update 14m13.269158s, update in background
2019/08/29 15:13:13 Time since last update 16m48.7796612s, update in block
2019/08/29 20:13:13 module.js:550
throw err;
2019/08/29 15:13:13 Time since last update 16m49.0784808s, update in background
2019/08/29 15:30:28 Time since last update 34m3.5628801s, update in block
And looking for a solution here on the community I tried with this commands:
sudo npm uninstall -g --unsafe-perm particle-cli
sudo npm install -g --unsafe-perm particle-cli
but getting the same results setting them as administrator or without being administrator and this was the last messages from cli after execute sudo npm install -g --unsafe-perm particle-cli
> node postinstall
npm WARN rollback Rolling back node-pre-gyp@0.12.0 failed (this is probably harmless): EPERM: operation not permitted, lstat 'C:\Users\general_user\AppData\Roaming\npm\node_modules\particle-cli\node_modules\fsevents\node_modules'
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules\particle-cli\node_modules\fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
+ particle-cli@1.44.0
added 1239 packages from 1324 contributors in 49.533s
C:\WINDOWS\system32>particle setup
What should I do? Should I reinstall the particle CLI? Thanks!
