Error: API User Not Configured when calling logic core APIs
Hello,
When trying to write a logic function that uses the list devices core API I get the following error:
Error: Particle API user not configured
    at job (particle-internal:user-code:5:12)
    at particle-internal:main:20:7
Here is the source code for the function, with our product ID abstracted:
import Particle from 'particle:core';
export default function job({ functionInfo, trigger, scheduled }) {
  Particle.listDevices('<PRODUCT_ID>')
    .then((devices) => {
      console.log('Got Devices');
    .catch((error) => {
      console.log(`Failed: ${error}`)
I've tried a few of the other API calls and they all seem to fail the same.
How can I configure this function to be authenticated with an API user?
Where is your logic block located? I suspect that you probably need to create a logic block that interacts with a product either within the product, or within the organization.
If you create a logic block at the top level of your sandbox, it won't have any API user assigned, because API users are scoped to product or organization only, not sandbox.
@rickkas7 I am creating a logic block within a product and passing its product ID to the listDevices function.
I have tried this again with a new function in another product to confirm and it is still failing
It turns out this functionality was not enabled for our organization, so the API user field was missing. Support was able to fix this for us.
